Question about Kodak EasyShare C875 Digital Camera
How to download pictures from internal memory to the memory card
How do I set the camera to record pictures to the memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Follow the instructions on this page of the user guide.
Posted on Oct 17, 2012
  • kakima Oct 17, 2012
SOURCE: Internal memory is full
u go to menu -hit down to where it says auto -it will bring up auto and internal memory...hit internal...then u can delete your internal memory the same way u do on your chip..
Posted on Aug 15, 2008
pontelemon
  • 538 Answers
SOURCE: internal memory full ??
In the settings switch from internal mem. to the card
Posted on Mar 25, 2009
  • 102366 Answers
SOURCE: transfer pictures from camera to card
First, make sure there's a card installed and that the camera's image storage location is set to internal memory.
Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
You set the image storage location in the Setup menu.
Posted on Jun 01, 2010
  • 102366 Answers
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Posted on Jun 17, 2010
Testimonial: "Exactly what i needed to know. Thanks!"
  • 102366 Answers
SOURCE: can i transfer pictures on the internal memory to
Yes.
  1. Set the camera's picture storage location to internal memory.
  2. Press the Review button, then locate the picture or video.
  3. Press up/down to highlight Copy>>, then press the OK button.
  4. Select an option and press OK.
Don't forget to set the picture storage location back to Auto or the camera will continue to use only the internal memory.
Posted on Sep 07, 2010
Testimonial: "GREAT ADVICE, THANK YOU"
**Help** The pictures I just took are gone, and its now on Internal Memory?
I believe you can take the memory card out and go to view pictures and when you find the pics that are on there select the pic and then hit the menu button on camera or settings button!! it should ask to send to memory card but first take memory card out and make sure that they are there then insert card and hit settings on the picture and select to send to memory card
Mar 25, 2012 | Fuji FinePix Z10fd Digital Camera
My camera always shoing memory full , i format the internal memory and format new sd card , same problem , still shoing the same , how can i fix it
Make sure that the camera is set to record to the memory card... often the internal memory will only handle a couple of pictures...
If it still shows memory full then a ribbon cable has come loose inside the camers and it is not recognizing the memory or cards...
heatman101
Apr 23, 2011 | Samsung NV3 Digital Camera
When i turn on my s5700 there is a message (images recorded to internal memory) then on the screen is a white box with black letters (in) i have done what the manual said and formated but it has not made...
Okay "normally" when the memory card is installed the camera reverts back to the memory card from the internal memory. Two things might be happening here one the internal memory needs to be downloaded to the memory card then saved to the computer and the internal memory card formatted. then the memory card formatted to clear those pictures. And or there is a setting switch in menu or set up that you need to manually switch from internal memory to memory card.
I know when I read this over it made scents so you might need to read it a few times to get the idea of what I'm telling you needs to be done
Apr 19, 2011 | Fuji FinePix S5700 Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
I do not have a cable to download pictures from the camera's internal memory. Is there a way to copy from internal memory to a SIMM card? Or can I purchase the necessary cable?
You can copy pictures from the internal memory to a memory card. Insert a card and set the camera's storage location to internal memory. Press the Review button, then the Menu button. Use up/down to select Copy.
Dec 02, 2010 | Kodak EasyShare Z7590 Digital Camera
Memory card
Use the camera not a computer to reformat the "card" or internal memory.
Make sure the setting in the camera is set to record on the card or internal memory. Whichever you are using.
Dec 22, 2009 | Canon Powershot A2000 IS Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
"Recording stopped. Record in internal memory "
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Recording stopped. Record in internal memory"
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
