Question about Honeywell Programmable Thermostat Heater
Install a digital Honeywell thermostat
I am trying to install a digital thermostat and I need to know the way the wires need to be hooked up.
    Scholar:
    New Friend:
  • 70 Answers
What kind of system do you have (furnace with heatcool, heat pum or boiler )? Is there a themostat there now. How many wires does it have. If you have a furnace and you have heat&cooling install red wire to r on thermostat white wire to w and green wire to g. The g wire is usually for the fan. If there is a thermostat there now the old one should have the same letters on the back by where the wires hook up. The color of the might be diffrent than the ones i used for an idea.
Posted on Jan 18, 2009
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
I have a red and a white wire only. I am installing a honeywell thermastat rth111. The heater is an electric air forced one. Where do I connect the wires?
These are not enough for you to install this thermostat properly. You could try hooking red to R and white to W2/E, but an electric furnace requires 4 wires for modern thermostats to run properly. If there are more wires in the line then it's a fairly easy task for a technician to add proper connections in, if not a new thermostat wire will need to be put in place.
Sep 25, 2011 | Honeywell Programmable Thermostat Heater
Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall.
Hook the black wire to the "R" terminal and the white wire to the "W" terminal...
That's all you have to do... then program the t-stat...
heatman101
Oct 14, 2010 | Honeywell FF12HH Thermostat
Wiring with Honeywell RTH6400
I have the same problem. I am Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall. Do I have the wrong thermostat. The manual doesn't explain this siutation.
Thanks!
Dec 29, 2009 | Honeywell FF12HH Thermostat
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Thermostat wires
just put a jumper between rh aand rc and use red, yellow you hook up to y1, white goes to w1, common is either black or blue.
Mar 27, 2009 | Honeywell Programmable Thermostat Heater
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
263 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
