Question about BenQ FP71G 17" LCD Monitor
Benq fp71 g + light stays green but no display
When i turn on my pc the orange light on lcd turns green. It stays green but no display.
dodgecharger
  • 254 Answers
SOURCE: BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Posted on Sep 17, 2007
SOURCE: I turn my monitor on and it displays BENQ and then goes to -No Signal Detected- Power light changes to orange..help?
IT MUST BE A DPI.IF UPPER THAN 60Hz THE PROBLEM WILL BE OCCUR AGAIN.I THINK
Posted on Oct 04, 2007
Mark_Webber
  • 472 Answers
SOURCE: BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Posted on Apr 09, 2008
SOURCE: BenQ FP731 Screen briefly displays then turns off
Did an independent diagnosis before finding this, and came to same conclusion. First found fuse PF751 was open circuit (3A black plastic fuse, not glass) over close to main heat sinks. When I replaced that with a fine fine strand of wire (for testing) then I saw Q759 (C5707) get hot. Checking the others shows that they should be driving into about 420 ohms on the primary side of the transformer for the flourescent lights (backlights) but on this one it was less than 1ohm. I've unsoldered the Q759 and now I measure 420ohms here too. Now I need to find a new C5707 or equivalent...
Posted on May 17, 2008
  • 3 Answers
SOURCE: benq fp 737s lcd computer monitor - model Q7T3 - NO SCREEN LIGHT
try to change ur power
Posted on Jul 11, 2008
The on off button on front doesn't turn the unit on and off. The light is always green (never orange). The display doesn't work either connected to PC with with D-sub or DVI-D. Is hw damaged?
Go to CMOS setting on your computer motherboard and check energy saving settings. Also check if your PC, motherboard, and OS are compatible with EnergyStar Power savings.
Aug 24, 2015 | BenQ FP951 (Blue, Gray) 19" LCD Monitor
My Benq t221w monitors power light flashes green ond will not turn on, the screen stays black, sometimes it will turn on but noe it stays off.
It is an inverter issue, you can seek a replacement but it would be more cost effective to replace the unit.
Mar 14, 2011 | BenQ T221W 22 inch LCD Monitor
My lcd monitor lights in green but does not display
That is definitely not normal. Try a different monitor on the computer and if you get video on the new monitor then you know your original monitor is bad for sure.
Sounds to me like its a problem with the lcd or the inverter. You might want to try and take apart the monitor and reseat both ends of the LCD cable. If that doesn't help then the monitor is faulty and you'll have to get another one.
May 12, 2009 | BenQ FP71G 17" LCD Monitor
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Robert
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Problem with moniter
i have BENQ lcd 15" monitor, the problem is that the menu appear atomaticaly
Aug 25, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Monitor turns it self off
exact same thing has happened to me. I have been told it's some part which often burns out on lcd's which can be replaced easily...
Sep 18, 2007 | BenQ FP91G+ 19" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
366 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
