I HAVE A GOODMAN HEATER MODEL 3 gmp100-4 rev b. the thermostat is digital and want light up I HAVE CHECKED THE THERMOSTAT AND IT IS GOOD I HAVE REPLACED THE TRANSFORMER ITS GOOD AND TERMOSTAT STILL WANT LIGHT UP . WHAT DO I CHECK NEXT ?
  • Perry Putnam
    Perry Putnam May 11, 2010
    Do you have 24 volts at the t-stat?
  • 52 Answers
Could be broken wire in wall
Posted on Aug 29, 2009
Goodman wall mount heater not working
What type of thermostat digital or manual, if distal try to pull off front cover n see if that turn it off if it does this means u have a bad thermostat n needs to be replaced. If it's a manual then try to disconnect white wire on w screw ,of course turn power off to heater , and see if that turn heater off if so replace thermostat. Hope this was helpful.
Dec 28, 2013 | Goodman Heating & Cooling
Inside Fan comes on but when you switch the thermostat to the on position it blows the circut board 3 and 5 amp fuses. All wiring was checked and eveything is wired correctly
Try disconnecting all control wiring at the furnace to the thermostat, then jump "R" terminal to "G" terminal, the fan should come on, then jump "R" to "W" the heater should come on, if the fuse holds after testing the problem is either with the control wiring to the outdoor control wiring or the thermostat and or thermostat wiring.
Sep 17, 2011 | Goodman CKL36AR36 Air Conditioner
Furnace will not shut off after the setting is reached. have changed thermostat. Temperature reading goes down on thermostat, furnace still runs. Model : Goodman furnace,gmh95/gch9
Check if your thermostat is set on 'o fan' setting.
If it is, trey to set it on 'Auto-fan' instead.
since it seem as if the heating does go off,only the fan may be running continuously.
this is possible if the thermostat is incorrectly set or installed.
good luck.
Jan 30, 2010 | Goodman GMS90703BXA Heater
Where is the pilot light on Goodman mod. PGB042100-1 REV A
This model has electronic ignition. You will need to remove the top panel, tape the door switch closed, have an assistant raise the thermostat above room temperature while you look thru the small window for an orange glow. If you do not see the glow, chances are you have a bad igniter.
Oct 18, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Oct 20, 2008 | Goodman GMS90703BXA Heater
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
