Question about Fisher and Paykel GC36 Gas Cooktop
Fisher and paykel gas cooktop electric ignition faulty
The electric ignition keeps sparking even when all burners are off. The valve (or knob) feels like it won't turn off all the way for the middle griddle burner. I smell no gas, and it usually stops sparking if I turn on the griddle burner.
  • Anonymous Feb 13, 2009
    i have the same cooktop it continues to click although it is not in use i have turned the breakers off, is this safe. what could the problem be
  • Anonymous Mar 13, 2009
    Exact same problem. Griddle burner constantly sparks. When I turn it on, it stops.
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: How do I remove knobs for burners to clean them?
To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
Posted on Jul 30, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have a 5
Hello & Welcome to FixYa
If you have already replaced the igniter and tried to dry out moisture with a hair dryer then the problem is with the spark module that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 23, 2011
  • 17 Answers
SOURCE: Pilot ignition will not stop clicking until the left front burner is turned on.
you have a bad set of switches and or a spark mod..
Posted on Dec 13, 2012
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Kitchen gas 4 burner cooktop
i think all igniter switch are grounded,i request to call expert technician to repair it, or uf u want u open the cooktop to see the igniter swicth at konb control area,clean one by one using thinner,remember switc off the plug first.
Aug 03, 2008 | KitchenAid 31 in. KECS100 Electric Cooktop
Fisher and Paykel GC36 Gas Cooktop Logo
197 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
