Question about Hampton Bay 24002 Ceiling Fan
New Hampton Bay Ceiling fan - runs only in clockwise direction
After a lot of effort I put the ceiling fan in my bed room, I connected
Blue & Black wire to House Black wire,
White to House white wire and
Green to House Ground wire.
The light is working and fan is working but only in clockwise direction with all 3 speeds. When I use the "switch" to change the direction, nothing happens to the fan, light stays on unless I switch it off?
What could have gone wrong here? Please help.
  • vishalchat Jan 21, 2009
    Next day morning I digged deeper into it and I discovered that 'pink' wire at one end of the switch has loose connection and needs to be soldered. I tested it and it works so I need to go get the soldering Iron and FixYa.
    Great to see your solution here.. it matches with my investigation...
  • 25 Answers
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Posted on Jan 18, 2009
CONNECTING WIRES FROM CEILING TO WIRES IN CEILING
Don't know that fan because it's a low-end store brand, But, if it has no remote;
White to white
black to black
blue to red ( usually)
If no red wire in ceiling then put black & blue to black house wire.
Sep 06, 2013 | Hampton Bay 24002 Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I HAVE A HAMPTON BAY CEILING FAN. MODEL FAN-2R
On the body of the fan motor is a small sliding switch(up and down), if you cannot reach it you can use a broomstick to carefully change it's position.
Sep 07, 2009 | Hampton Bay 24002 Ceiling Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
339 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
