Question about Ricoh Aficio MP1600SPF Copier
How do i set up the developer on initial set up
  • Dave Toombs
    Dave Toombs May 11, 2010
    Hi: what do you mean by "initial set up"? Have you replaced the developer or drum unit?
    Regards Munybuny
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Hope you have already installed the developer, please
Enter SP mode, press Clear (yellow) button, < 1 0 7 > and press and hold the Stop (red) button for 3 seconds.
Then execute SP 2214.
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
Model 2000 copier. what does error code 392 mean?
TD SENSOR INITIAL SETTING ERROR.
TD sensor initial setting is not performed correctly.
1. ID sensor defective
2. No developer
3. Drum does not turn
4. Development roller does not turn
5. Poor connection of the PCU
6. The voltage is not applied to charge roller
Mar 13, 2016 | Ricoh Office Equipment & Supplies
Error message SC350
Clean your charge roller and developing unit, and replace the developer, after this, go to 2801 (TD sensor initial setting) , then press start, and then to 2805 (developer initialization), after this go to 3001 press start for id sensor PWM setting.
Thanks,
Ben.
Jul 05, 2011 | Office Equipment & Supplies
What can correct an SC392 on a Ricoh MP W2400?
SC392:Toner density sensor initial setting is not performed correctly.
  • No developer
  • Developing roller does not turn.
  • Development roller coupling gear is not correctly attached.
  • Poor connection of PCU
  • ID sensor defective
Source: Ricoh Errors
May 06, 2011 | Ricoh Office Equipment & Supplies
How to install developer in a new Ricoh Aficio MP1900. I have a new MP1900, there is no istructions to install developer in the machine, I know that I need enter in service mode to set developer: someone...
I suppose you have the developer in the developer unit, YES????
If so you just need to do developer initialization.
Press yellow key.
press on the key pad 107.
Old red key at least 3 sec.(if you did everything well you are in SP MODE)
Press 1 (to copy sp)
Search 2 drum (one time on the left key)
Press ok
Search SP 214 Developer initialization
Press execut
Hope you understood. Good luke.
Feb 17, 2011 | Ricoh Office Equipment & Supplies
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
How do I fill developer and initialize
You must replace the whole Photoconductor unit, Type 1027.
This unit includes drum and also developer.
Then switch on the machine and it is initialized automatically.
Jan 17, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio MP1600SPF Copier Logo
131 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
