Volume touchpad has frozen on mute
I have a new Acer Aspire 6920G the touch pad on the left of the keyboard has frozen
  • 2 more comments
  • Anonymous Feb 28, 2009
    My axcer 6920 has the same problem... wat do i do?
  • Anonymous Mar 16, 2009
    the touch pad on the left of the keyboard has frozen on mute and full volume
  • danmc64 Apr 04, 2009
    Same thing... Cinedash media console frozen on mute and full volume. Whats the deal and how do you fix this?
  • Pat Batta
    Pat Batta May 11, 2010
    did you restart system?
    removed media?
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
Posted on Jan 18, 2009
Same happend to me once, static buildup. turn off the pc, remove the battery, put it bck in and it will work. Atleast that is how i fixed it ;) sorry for my bad english.
Posted on Jun 25, 2009
  • richellelaza Jul 09, 2010
    thanks.. it helped a lot.. God bles.. :)
My acer 8920G Cinedash console froze on me and I had to remove the battery for about an hour then everthing was good.
Posted on Apr 05, 2009
Froze on mute, because you are listening to **** you should not be. Put on some good old gospel music and the problem will go away :)
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
Frozen synaptic touch pad
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 09, 2012 | Acer Computers & Internet
Sound touchpad frozen on mute acer aspire 6920G.
Remove the power cable and battery. Hold the Power button on lap for 60 seconds. Connect the Battery and power. Check whether this works or not. If NO give me the details of the system (which OS is using).
Dec 21, 2010 | Computers & Internet
Touchpad is frozen
Are there any drivers installed for the touch pad ?Use an external USB keyboard temporarily.
Sep 27, 2010 | Acer Aspire 7720 Notebook
My touchpad has stoped working on my Acer Aspire 5732 Z
Sometimes it differs but you can try pressing FN and F7 together on your keyboard to see if that will enable the touchpad again.FN should be next to your left-ctrl on your laptop keyboard.
On other Acers, there's either a seperate button to enable the touchpad or a different Function key. See on your keyboard the function keys and choose the one that looks like a tochpad, with a pointing hand. Sometimes the icon on the key just looks like a mini-touch-pad.
May 28, 2010 | Acer Aspire 5720-6661 Notebook PC
Volume control frozen
upload a new driver, or install it again
Dec 20, 2009 | Acer Aspire 6920 Notebook PC
Cinedash touchpad
Try taking the battery out for 10 seconds, put it back in and boot as normal.
Worked for me on my Aspire 6920G! I think it must be a power-ratio problem.
Mar 29, 2009 | Acer Aspire One PC Notebook
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
Nov 19, 2008 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
1,493 people viewed this question
David Payne
David Payne
