Question about Whirlpool LGB6000KQ Gas Dryer
Whpool gas dryer turns but it is not heating up. Mod # GGW9878PWO
The repair person has been out twice since Sept. He replaced the gas coil valves and cleaned out the exhaust manifold. Now, we are not getting any heat.
Although the dryer is off, we can still hear a ball-bearing noise. It stops when we unplug the machine. Any suggestions would certainly be appreciated.
Do I have a lemon? Is it time for a new dryer.
Tim
works but wont heat
    New Friend:
I have a whirlpool gold ultimate care II dryer model GGW9878PWO. It runs fine but mid cycle it will make 5 short beeps 3 times and shut off, then it will automatically go back on again for a while, beep and shut off again and then go back on until the cycle is complete. Is this normal? If a problem what is the cause?
Posted on Apr 09, 2013
Coil starts and then cools down
Posted on Jan 18, 2009
2 Suggested Answers
godtech
  • 51 Answers
SOURCE: Whpool gas dryer turns but it is not heating up. Mod # GGW9878PWO
#1 MAKE HIM COME OUT AND FIX IT FOR FREE.ALSO THEIR IS A SMALL WHITE OVER HEAT FUSE IN THE BACK OF ALL DRYERS.MAKE SURE NOTHING IS INSIDE YOUR TUMBLER.
Posted on Jan 16, 2009
The Kenmore 110 87880800 gas dryers starts up, ignites the gas initially, then 15 min later the dryer stops heating but continues to turn the drum. If we let the dryer sit for 20 min and turn it back on,...
Your dryer is heated by gas and what is happening is,when the coils that open the gas valve work when they are cool but once the dryer is running and the gas valve coils get warm they wont work,this is pretty typical of a bad gas valve coil.Replacing the coils will fix that.To replace the gas valve coils,UNPLUG THE DRYER, use a putty knife and place in the seam between the main front panel and the small lower front panel AT the corners and depress the clip that holds small panel to main panel.On the right side of the base frame behind the small panel is the burner asm. the coils are held to the gas valve by a bracket remove that bracket and replace the coils, they are black round shaped and one has 2 wires and one has 3 wires the plugs pull off and can be push onto the new coils with just a small amount of pressure.
The part # for the coils is 279834 They can be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
repairclinic.com
appliancepartspros.com
assuredparts.com
I hope i have helped you to be able to repair your dryer,
Gene
Aug 07, 2011 | Dryers
My gas dryer is 3 years old and it starts to heat up when it is turned on and then stops heating while running.
This is usually due to the two gas valve solenoid coils sitting on top of the gas valves, one with 3 prongs and the other has 2. The coils work fine when cool but one or both are weak and fail when get heated. Both coils must work to open the two gas valves in order for the dryer to fire up. The coils are not repairable and the only viable solution is replacing both of them. Replace the solenoid coils and it should solve the problem.
Feb 28, 2011 | Amana DLG330RAW Gas Dryer
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
Gas dryer will not heat up
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams to assist with all your DIY needs.
Firstly, ascertain that have made a positive heat selection, then read on.
Igniter
Gas valve coils
Thermal fuse
Jul 12, 2009 | Maytag Dryers
Maytag performa dryer will not heat up
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Dryers
Maytag dryer Model # ldg9304aae , Dryer won't dry intermitantly, may not be lighting. Don't hear igniter
Firstly, ascertain that you have made an adequate heat selection, then read the checklist below, provided by; www.repairclinic.com. They also provide disassembly diagrams and repair parts.
Igniter
Gas valve coils
Thermal fuse
Maytag neptune (gas dryer) just stopped heating up...was working fine yesterday. The dryer is 8 years old...never a problem. Does the heating elements need replacement?
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Jan 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGC8858EQ0 Natural Gas Dryer Problem: The dryer no longer heats up. Power is good to the dryer, gas line is turned on and both it and the vent are unobstructed.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp
Temperature Switch, make sure a positive heat selection has been made. Then check these:
Igniter
Gas valve coils
Thermal fuse
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 04, 2008 | Dryers
Dryers Logo
302 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
