Question about Palm Treo 600 Handheld
Treo 600 This guy has two problems, one old and one new. Old problem: I bought this used on ebay and was told there was no sound. Which is true, there is no sound - except when I put it on or take it off the charger. Why does it only work for the charger? I am pretty sure someone has been inside it because it sure looks like a big (dirty) thumbprint on the top half of the inside of the screen. That is not the problem, just a weird thing, which may have something to do with the absence of sound... The more recent problem just started. I was reading an ebook a few days ago and two pixels turned yellow. I did a soft reset and they were still there. Later, I powered the Treo off for a while and when I turned it back on, there were more yellowed out pixels. Now it looks like a bird, at least 20 pixels are bright yellow, almost right in the center of the screen. Does anybody have any idea if this is a permanent problem? I can hotsync, then do a hard reset if I think it's going to help, but am wondering if I would be wasting my time. TIA if you can help me, especially with pixel advice. Roxanne
The problem with the screen pixels turning permanently yellow happened when the touchscreen have had a continuous pressure on it (destroying the licuid cristal display pixels; there is no repair other than touchscreen replacement. Regards, Mauricio [email protected]
Posted on Jul 04, 2007
SOURCE:
The touchscreen for my treo 600 does not work!!?
plz reset the mobile and go to settings /...u will find an option for pen maximisation .....it will resolve the issue
May 11, 2009 | Palm Treo 600 Handheld
Palm Treo 680 cracked LCD screen
I've got the same problem, but I tryed to use my old one, because in that just the lcd panel was damaged, not the touch, I've put the Touch screen panel old one in the new one Lcd i've bought, and the problem was in the touch that came on my new Lcd, the old one worked great.
I was luckely.
Sorry my english.
Apr 25, 2008 | Cell Phones
Palm Treo
Sounds like a defective phone...
I'd return it again... mark it to see if it's the same phone being returned to you....(perhaps inside the battery area) then try for
a refund if it happens again... if no refund available... check out
www.palzasettlement.com
for a defective phone legal settlement offered by Palm
I hope this helps.
Jan 25, 2008 | Palm Treo 600 Handheld
My Treo Hard resets repeatedly
Do a simulated-battery-disconnect reset. This is a harder reset then the hard reset. It will simulate disconnecting the battery at a hardware level, so it will completely toast anything on your treo that might be causing the problem. Don't worry it won't hurt your firmware or anything, just all the data will go.
Hold down the BACKSPACE key, and the K key.
While holding it, press and hold the reset button using the reset tool on the stylus.
Hold all three for a few seconds. The treo should turn white, then turn off. If it won't come back on, then you've succeeded.
To get the treo to turn back on, plug it into the charger cable. In a few moments the treo will turn back on, and ask you for your language and regional settings, just like when you first bought it.
If this doesn't fix it, you have a hardware or firmware problem that will be far more difficult to diagnose/fix.
Dec 14, 2007 | Palm Treo 600 Handheld
Treo 600 screen
Replace the LCD but I do not think it worth it. You can get a used Treo 600 for less than $50 from Ebay. Do not bother
Dec 08, 2007 | Palm Treo 600 Handheld
Palm One Sprint to Cricket Treo 600
This is a problem with the Treo 600's, because the phone is starting to get old and isn't compatible with some gsm providers anymore.
When it is happening, perform a soft reset (push the reset button on the back). Occasionally this helps, but NOT all the time.
Your best bet is to upgrade to a later model treo, like the 680.
Nov 27, 2007 | Palm Treo 600 Handheld
Noise problems
This is a common problem, the solution is actually called the "Treo Buzz Fix".
Earlier models of the Treo 600 had an unshielded cable that connects the battery to the main board. This cable causes loud buzzing and interference on the Treo.
If your treo is under warranty (unlikely probably...) then send it back to Palm for replacement.
If not, try the fix. The fix involves disassembling your Treo and wrapping aluminum foil around the offending cable. Here is a guide:
http://mytreo.net/treofaq/BuzzFix
And here is a forum on MyTreo with high resolution pictures of the process, to help you:
http://mytreo.net/forum/index.php/topic,54886.msg429525.html#msg429525
This is a somewhat dangerous procedure. It is possible to damage your treo if you aren't careful. Follow all instructions EXTREMELY carefully.
Good luck! And don't break your Treo!
Nov 20, 2007 | Palm Treo 600 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Touch screen not working
The digitizer can sometimes be damaged over time. I would suggest removing the screws from the back of the device, and then reseating the screen ribbon cable.
Aug 07, 2007 | Palm Treo 600 Handheld
Replacement Treo won't load my info
I would suggest doing a hard reset on the replacement treo. After that do a hotsync, and choose exhisting user from the drop down menu. This should work.
Sep 01, 2006 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
96 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
