Question about Mitsubishi HS-U445 VHS VCR
Error message E4 and stuck tape
Vcr is displaying error E4 and when I eject the tapes, the casset makes it out, but is stuck because the tape is still wrapped up inside. Is this fixable?
  • 2 more comments
  • todd dion Jun 25, 2007
    I got the tape out in one piece, and I tried to run the head cleaner through. It won't even play a tape. The tapes aren't getting wrapped up, they are just not winding back up when I eject it. Is one of the wheels not spinning??
  • todd dion Jul 07, 2007
    I believe I found the issue. The capstan motor is not even engaging. Do you know where I can find another one of these for this model?
  • todd dion Jul 15, 2007
    It turns out that it was the capstan motor. I found one for my model available online for $60. That will not do..
    However, I found someone nearby selling my exact model on craig's list. His had an issue with the tension roller. I replace my capstan motor with his, and now it works perfectly. The belt is in perfect condition.
    Thanks anyway.
  • salty561 Feb 11, 2008
    Used Sony 8 hour tape which is possibly slightly thinner and it got eaten up inside the fast rewind and is still stuck in there. I got the cassette out but the tape is hanging out the front on both sides. Any chance I can remove the tape and save.
    Genius:
  • 2,985 Answers
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Posted on Jun 22, 2007
  • john ash
    john ash Jun 25, 2007
    Can you operate the machine with the cover off?
    Then you will see what is/not happening
  • john ash
    john ash Jul 08, 2007
    they don't make VCR's any more - so new spares are going to be problematic
    It is possible that small parts are common
    So look around for something that has been junked to cannibalize.
    Most like however the capstan does not spin because the belt has broken
    Now belts should be about, cab can be made from another belt cut to size and joined with Super Glue
SOURCE:
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
Jul 31, 2012 | Mitsubishi HS-U575 VCR
JVC S-VHS VCR 2002 model
TRY A HEAD CLEANER,,AND BLOW IT OUT
May 14, 2009 | JVC HR-S9800 S-VHS VCR
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Mitsubishi HS-U445 VHS VCR Logo
571 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
