Question about Brother MFC-3220C Plain Paper Inkjet Fax
My fax machine says pls open cover
I hvae tried to replace ink, turn it off for several hours, clean it and everything still can't print or fax just says pls open cover
  • barnese23 Jan 18, 2009
    I have a MFC-3220C and the machine says to pls open the door, when I open the door, after opening the door it says to pls close the door, I have cleaned it, changed the ink, and closed the door gently and then got mad at it and slammed the door and it still doesn't work.
  • STEVE RAYMOND May 11, 2010
    hellop1 I AM A BROTHER TECH, PLS GIVE ME MORE INFO SO I CAN HELP YOU THANKS
  • 89 Answers
Very likely you have some paper stuck in the printer. Try to lool for it and remove the stuck paper
Posted on Jun 24, 2010
Will not print black even with a brand new cartridge
Brother has had a problem with this model and several similar ones not printing black. If it's still in it's one-year warranty, find a service center here, and Brother will pay the servicer for everything. If it's just out of warranty, call Brother and beg for them to issue a Service Request, which is like an extension of the warranty for this one situation. They'll replace your printhead and all ink cartridges. (It may still come back low on ink, because it uses a bunch of ink purging air and old ink from the tubes & head after the repair.
But before all that, try several cleaning cycles, and make sure you have genuine Brother ink in the machine. Brother won't pay for a repair on this unless it has their own ink in it.
If it's long out of warranty, it can still be repaired, but will probably cost more than a new machine.
Mar 11, 2011 | Brother IntelliFax 1860C Plain Paper...
Machine error 41
Very likely your print head is faulty. You can get it replaced or try the economical solution below.
I had the same problem after replacing the print head. I removed the ink cartridge and then unclip the two metal two clips by the side that hold the print head. Then I used WD40 to spray through the ink holes until the clear liquid comes out from the print head.Then I replaced everything back and start the cleanning process, do a few test prints. It works ok now, no more Machine Error 41. Therefore, sometime the problem might just be clogged pin heads!
May 15, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
Lou
Oct 17, 2009 | Brother MFC-685cw InkJet Printer
Brother mfc 3360 model mostly problem is no printout, pls soluti
Hi!
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
To verify the ink cartridges are installed correctly follow the steps listed below:
Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
The LCD may then display:
Did you change xxxxxx? Yes No.
The LCD may display this question for the color(s) that was replaced.
Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
After all the correct selections are made, the machine will then go into a cleaning.
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
Press the Ink or Ink Management key.
Use the up or down navigation key to select Test Print.
Press OK to confirm your choice.
Use the up or down navigation key to select Print Quality.
Press OK to confirm your choice. Press the Color key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | Brother MFC-3360C InkJet Printer
Have a Brother multi-functional MFC685Cw. Rarley printed anything with it. Always uploaded any fax and printed it through the office laser. Everyday this thing cleans it self and after 6 months of no...
Ink and Toner is how Fax and Printer companies make their money, the machine is just a way to sell supplies.
Yes, you will have to replace the Toner/Ink because they lubricate the print heads/drums.
Nov 24, 2008 | Brother Office Equipment & Supplies
Black ink not working
Have you carried out any head cleaning cycles. If not, do it, then a nozzle check. Any sign of ink? If so do a couple more nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat. If you already have done lots of head cleans with no result, and you're sure you have a good ink cartridge in, then you can try soaking the print heads for 24 hours (or more), as follows.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Aug 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Jan 18, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
"printer error - check paper" after cartridge replacement
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
283 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
