Timer not timing or moving machine not cycling not aggitating or
Machine not aggitating or spinning also the timer nob is not advancing through cycle
  • mkychel Jan 17, 2009
    washing machine filling up with water but not switching to the rinse or spin cycle
  • 15,935 Answers
It appears your timer and/or pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
Sep 20, 2012 | Maytag SAV3710AWW Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer won't advance from cycle to cycle
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
Nov 16, 2008 | Danby DDW1805W Designer Series...
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
