Question about Apple iBook G4 Mac Notebook
Computer won't show start up screen, only shows different colors ie. green, then pink, blue... i took out the battery and started it without the battery and got the same results.
  • ssaul Jan 20, 2009
    my computer will not show start up screen and keeps asking for a user name and pass word and then will not accept it.
  • Anonymous Feb 21, 2009
    same problem
    Sergeant:
  • Apple Expert
  • 250 Answers
First you need to reset the PRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Next you need to reset the PMU (power management unit). This will depend on the model of your iBook so follow the instructions on Apples page:
http://support.apple.com/kb/HT1431#faq6
Hope this gets you going again
All the best
Sean
PiDigital
Posted on Jan 19, 2009
It was brought to the Apple store and sent off for troubleshooting.
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Compag laptop connected to LG HD TV. TV screen just show blues and greens, no reds. What do I need to do
To troubleshoot this, you must first start with the obvious. Check your cable connections/try replacing the cable. If this does not work you should then check the color settings in the tv. If that still does not work you can try connecting your laptop to a different monitor/tv. If the color shows up with the same problem, you know the issue is contained within the computer itself. Possibly bad VGA/HDMI Port or color management settings.
Nov 18, 2010 | Compaq Computers & Internet
Wire color abbreviations Isuzu Rodeo
P - Pink
LB - Light Blue
V - Violet
GR - Grey
LG - Light Green
BR - Brown
L - Blue
Y - Yellow
O - Orange
G - Green
R - Red
W - White
B - Black
Some wires will be allocated 2 colors ie B/W. This is a color with a different color line running along its length.
The first denotes the main color (Black in our example) and the second denotes the tracer line (White in our example)
Sep 09, 2010 | 1992 Isuzu Rodeo
Asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a while and then shows the same problems.tried different graphic cards and get same result or would show all...
http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-D667&s=775
Select your operating system. If this model has onboard graphics, download fresh VGA driver, remove your graphics card and see if you can get any results.
Nov 23, 2009 | Computers & Internet
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
Color Display problem
it seems that problem that ur facing is manly related to drivers but try booting into safe mode and incase ur screen look normal in it try installing the driver from support.dell.com.or check in bios and check the screen in case ur screen is still bad then contact dell
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Different colors on the scanner screen
I didn't find a fix. I went to Best Buy and they said it would cost more than it was worth to fix. So I bought a new one. Thanks, mittenshadow
May 29, 2008 | HP ScanJet 5300C Flatbed Scanner
Apple iBook G4 Mac Notebook Logo
1,013 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
