Question about Lexmark X1270 All-In-One InkJet Printer
Need to install my lexmark 1200 on my computer
The conective cable is ok. what is happening
  • 81 Answers
Well i would recomend you to disconnect the printer from the system & then uninstall the software & then reinstall the software using the installation disks.. & in between the installation when it asks to connect the printer cable... then only connect the cable to the computer...
Posted on Jan 18, 2009
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
HMDI Conection
HDMI port on TV could have bad connections....happens sometimes when plugging and unplugging cable...machine soldered....bad weld!!!
May 19, 2010 | LG 37LG30 37 in. LCD HDTV
Network conection error 9?
lan cable,lancard,ip,cable conection problem. check this
Jun 25, 2009 | Microsoft Windows XP Professional
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
SAMSUNG E250 CELLULAR PHONE WHITE SCREEN
Ok this has happened to me, i havent done this yet but all solutions seem to point towards a broken display/ribbon cable... ive had a look inside mine and the cable seems fine however it could be the conection between the ribbon and screen, this will require a new screen....ill have a look on ebay and post what i can find.
Oct 29, 2008 | Cell Phones
Ps3
I assume you have nowhere to connect the red cable.
This is ok. The A/V outlets on your TV only has 2 ports. It's ok to plug the yellow and the white and leave the red.
Jun 07, 2008 | Sony Playstation 3 (PS3) Console
Still messed up.
hi yes it should be in recovery mode when doing this
does the firmware tell you when to connect the mp3 player to computer once in recovery mode open firmware file then when it asks to connect then plug into your comp if it dont work this way then plug into comp before opening firmware file give this way a try also.
But the mp3 player needs to be in recovery mode whilst doing this
if this still dont work then try a different usb port failing this then their is a problem with either the cable or usb port or conection on mp3 check cable and connections at both ends make sure no dirt or paper is stuck in mp3 end ok
Let me know what happens ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Conecting DVD/VCP to tv through DIRECT SAT. BOX
You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
Feb 26, 2008 | Televison & Video
When i connect Usb cables System restarts.
Check the BIOS setup with the Manual- is there something disabled the should be enabled or vice versa? Try another type of USB device in the socket to see if it is the cable or the board faulting. If the board is OK at this time - try plugging in a hub- and if it is OK plug up through that. Otherwise it seems to be a board fault.
May 15, 2007 | Intel D101GGC Motherboard
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
