Question about Garden
Starts on first pull. Runs about 30 seconds and dies.
Got two mowers from a friend. Both had way too much oil. Drained and refilled with 20 oz. of oil. Both mowers are like new. They start on the first pull, run for about 30 seconds and die. While running they smoke and run rough. Once they die they cannot be restarted until they sit for a long time. (maybe a couple of hours) When started it's the same thing again.
Found the air filters on both mowers were so saturated with oil there was not enough air getting to the carburetor. Cleaned the filters first with dishwasher detergent and hot water, dried them, then soaked them in aclcohol to remove more oil. Dried filters, installed on mowers, and both mowers now run fine.
Posted on Jan 18, 2009
Mower starts, and stops after a few seconds
could be a stuck fuel solenoid or clogged carburetor
Jun 06, 2013 | Parks Optical 13.5hp Briggs And Stratton...
Mower starts, only runs for a few seconds and shuts off
did you blow the carby out with compresed air
Jun 06, 2013 | Garden
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
I cannot locate my manual; can you please tell me how to change the oil?
Simplest thing to do. Remove spark plug wire for safety. Remove oil filler plug. Tip mower to the side the filler neck is on with a bowl waiting on the ground next to the mower to catch the used oil. When empty, tip mower back upright and refill with 20 oz of 30 weight non-detergent oil. Put filler cap back in and check level. Replace spark plug wire. Thats it!
Jun 25, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
