Question about GE GSH25JFR Side by Side Refrigerator
Ge ref. making clicking noise not running display not working
Ref. just sits there and keeps clicking forever.....won't start running and display won't work on the inside where i adj temp...says -47 on both displays. Lights dim in frige when it clicks while door open..
  • tedshome11 Feb 26, 2009
    I have the same problem as jyatess's but with a GSH25SGRE.
  • jbroaders Mar 15, 2009
    Fridge keeps tick tock clicking, Ice maker packed in months ago, water dispenser has just died, massive build up of ice in freezer area. Think this all originated because spring on ice chute was week - so constant snow on chute.
Replace the main board on the back my was about a $130 at a wholesale parts store and i put it in
Posted on Mar 06, 2009
  • 306 Answers
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 17, 2009
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
Our GE Monogram (model #ZFSB27DAG SS) side by side is not keeping the refrigerator side cold. It seems to be working fine on the freezer but not the ref. although the ref. side does work but just barely....
First start by Cleaning Your Condenser. If your condenser is extremely clogged. Clean it and let it run over night. Then check if there is a difference in the morning. If your condenser is clean then disregard. Make sure that you have good air flow into the fresh food(refrigerator) section threw the damper control. Click here to see your damper it is number 426. Another thing to check. Open your freezer and look on the back wall to see if there is defrost frost forming. Sometimes you have to remove the back panel to verify if your coils are clear. If you have a defrost problem starting it will restrict air flow into the refrigerator section. This is the most common problem on your model. If you remove the panel and the coils are frosted and restricting air. You can take a hair dryer and defrost them to get yourself by for a few days. This would either be your defrost termination switch, defrost timer or defrost heater bad. Here is your UNIT. Click Here to contact me.
Apr 04, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Moved ge ref to new house was working fine, when plugged in now makes "clicking sound from circuit board, compressor not running
You may have a bad board and just now it is coincidentally showing the problem.
Have you tried unplugging the unit and letting it sit for a length of time?
The bards are expensive but fairly easy to replace, just be sure the power is disconnected prior to removing the cover. You may see a burned spot on the back of the board behind the compressor relay, you can actually re-solder this connection to save money if that is the case!
Jun 11, 2010 | GE Profile PDS20SBS Stainless Steel Bottom...
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Fridge not working, freezer is
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
If you want mor info to DIY check out: ronbuice.com
Dec 16, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
General Electric model # GSS25JSRFSS
if your appliance is humming then your motor might be out. Im not positive but i had a similar problem of the humming and clicking and the entire motor burned up. Might be a reason the lights are fading and such... Hope this helps
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
334 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
