Question about Craftsman Garden
Belt replacement on Craftsman LT 1036
This Craftsman LT 1036 threw both belts. I've got new belts but can't figur out how to relcae the trany belt. It looks like one of the trany braces needs to be insdie the belt loop so as not to rub the belt, but that doesn't make sense to me. I can't find a manual or any diagram on how they should go. Any ideas?
EarthJam
  • 23 Answers
SOURCE: Craftsman 22 HP automatic/46 How to install drive belt
Hey jim the drive belt connects to the fron of the machine Just above the PTO clutch. connected to the vertical crank on the engine. It slips through a series of pullies to the back side od the mower. One pully will be on a tention spring. that is your golden ticket to getting the tention you need.
Looking at the pullys. for routing your new belt. V pullies for the inside portion of the belt and flat pullies for the outside.
You can usualyl take the chassis and pedals off as needed. the pebals have pins holding them on.
the seat has a safty switch that gets unplugged.
There are bolts hidden under the foot map as well which snaps up and down careful with these as that mat will never be the same if you break the clips.
THe back of the mower near and above the gastank you will see a pull thats ontop of a hydrostatic pump thats the last pully.
I have done these before without removing the body. However its not easy and you had better be limber.
Ohh and of course remove any decking under the mower for mowing lawns. =) i hhope this helps if i see a diagram i will try to link you. GL buddy -Jeff in alaska
Posted on Feb 03, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
  • 376 Answers
SOURCE: belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Posted on Jul 29, 2009
SOURCE: craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Posted on Aug 20, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for Craftsman LT 2000 42
Look under the "running boards" Sears(AYP) sometimes put them under there. If not, go to www3.sears.com, type in your 917.xxxxxx model number and the pictures will show you an exploded view of the belt configurations
Posted on Sep 14, 2009
I replaced the drive belt on my craftsman lt 2000 riding lawnmower mo 247.288841 42 inch deck .But now when I tried it it worked fine going slow but when I tried to go fast it goes slower please help.
Go back and check the belt routing very carefully. Make sure all the tensioning springs are in the correct holes. Make sure the belt is on the correct side of all the belt keepers.
Mar 15, 2017 | Craftsman Garden
I have a craftsman Lt 1500 and the belt came off is there any way u can tighten it without having to replace the belt?
All belt driven machinery has some way of adjusting the tension and to aid removal and replacement. Look for a tension pulley or a way to slide one of the pulleys closer or further away.
Oct 03, 2015 | Craftsman Garden
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt 2000 42
Hi, first check the spring that pulls on the idler pulley for lost tension then run the blades for a 10 to 15 minutes at half to full throttle. This is necessary to bed the new belt into the old pulleys. Regards Phil.
Sep 05, 2012 | Garden
Replacing a the belt on a portable air compressor - craftsman
hi mate if the pump is connected then it doesnt have a belt its direct drive and if the motor is seperate from the pump unit then it belt driven i dont understand as the picture is a direct drive (no belt)
Aug 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Mar 15, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
423 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
