Question about Car Audio & Video
Roof Console on the espace
Hi I have got a renault espace 2000/1996 /, how do i take the roof cosole off to put a aerial in thank you
You can get to the aerial mount by removing the over head console. you need to unclip the front section (nearest the windscreen) then two screws and the console will drop down reveling the aerial mount.
Posted on Mar 12, 2009
My back shelf don't go down on my Renault so I can't see behind me
it sounds like the reed switch that activates the parcel shelf is faulty
if the car belonged to me i would go to a renault dealers workshop
they have the knowledge of that roof mechanism and will be able to diagnose and repair
Aug 19, 2016 | 2005 Renault Megane 1.6
How do i manually put the roof up on a renault megane 2000 convert
Sorry, they just don't put manual controls on them. If they did that, How would they be able to sell you expensive electrical parts?
Dec 08, 2014 | Renault Cars & Trucks
Hi, I've just got myself a Grand espace and have a problem with the roof, the sun shade opens fine but when I switch to the roof It moves slightly and then a load clicking noise starts, is my roof stuck as...
there is a gear on the motor they do wear out. try to give it a hand a few times if it makes a crunching sound wile you giving it a hand the the gear is warn out.
Oct 13, 2013 | Cars & Trucks
Why does my radio on a Corsa Design 2007 only pick up the bbc radio channels? I have just bought the car.I have no arial on the top of the car.
You should have an Aerial mast on the roof of the car, it should be situated at the rear of the roof in the centre. All Corsa`s come fitted with an Aerial as standard so it should be there. If it is missing or broken then you will only be able to pick up the BBC stations as they have the strongest signal strength.
The Aerial consists of a base section attached directly to the roof and a mast which is removable from the base by simply unscrewing it, it`s not uncommon for the mast section to get pinched as it`s easily removable but they can be bought separately from any any vauxhall dealer and are easily replaced.
Hope this helps and thanks for using fixya
Dec 23, 2010 | Car Audio & Video
Have renault clio 53 plate expression with leaking sunroof which is on passenger side by sun roof - any clues or idiots guide as to how I can repair plse?? Damsel is getting wet!!! Thanks
There is a special sealer tape from RENAULT or get sealer from B&Q and go around the rim between the car roof and the sunroof all the way round
Dec 17, 2009 | 2006 Renault Le Car
Leaking clio r reg
seal around the sunroof with some sealent
Mar 29, 2009 | 1986 Renault Sport
Renault megane cabriolet roof broken?????
just had the same problem with mine, here's what the problem was, the hydrolic fluid had gone bellow the min level indicator because of a slight leak to the ram, the reservoir is located in the back N/S boot. refill the the reservoir (Halfords do the hydrolic fluid for them) then you need to re-set the roof mecanism, after opening and closeing the back part of the car where the roof goes manually, and trying the switch a few times to reset the locking device with the micro switches, I managed to do it without spending too much cash. hope this helps anyone with roof trouble. -
Mar 24, 2009 | Renault Sport Cars & Trucks
Leak in car
This is probably the sunroof seal itself, and are stupidly expensive.
Try this as a first shot -
Clean the seal with the roof open fully to remove any moss algae or dampness. Let it dry out properly.
Next, Use a silicone product for tyres to make them look glossy. This is formulated to help rubber retain it's flexibility - and is also an excellent moisture repellant.
You can close the roof while still wet with the stuff. It won't matter.
I did mine last winter when I had a wet drivers seat due to leaks.
No problems since.
If this works for you too, Please rate as Fixya so others may follow. Thanks.
Jul 07, 2008 | Renault Sport Cars & Trucks
Coaxle cable (from aerial on roof to TV or top box)
I believe that you use the same type of connector as in the UK.
If so, this site or this video should help you.
Even if your connector is a slightly different design, the principles are the same.
Hope this helps,
Mar 05, 2008 | Audio Players & Recorders
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
