Question about Dell Inspiron™ 600M PC Notebook
No Power My 600M stopped charging and will not work with DC power pack. I replaced the DC Power Jack and purchased a new power supply. It still does the same thing. The green light on the power supply goes out immediately after I plug the cord into the DC jack. I welcome all the help that anyone can provide. Thanks
  • wccx4jg24 Nov 27, 2008
    How did you go about replacing the DC Jack, I think it is the only problem with mine, but I cannot get down to only the motherboard, there is some kind of plastic internal skeleton that I cannot find a single screw or other way to detach so I can clearly get to the jack.
  • rickhaugez Apr 28, 2009
    AC POWER CORD I HAVE TWO OF THEM AND TWO BATTERIES FOR NOTEBOOK IT DOES NOT POWER UP BECAUSE BATTERIES ARE NOT GETTING RECHARGED AND AC POWER NOT WORKING HOW OR CAN YOU REPAIR AC ADAPTER IN NOTEBOOK OR IS IT A MOTHERBOARD PROBLEM?
    Genius:
  • 2,985 Answers
This is a motherborad problem If the machine if new-ish contact Dell A reair shop may be able to help- but a machine that is more than say 2 years old is proba;by better simply to replace it.
Posted on Jun 22, 2007
SOURCE:
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
I have a HP dv7-1240us. My power supply went bad. I purchased a new one now my cpu doesnt charge or even power up. Need some help on how to replace the power socket. I have no idea on what else it could...
Was the new one that you purchased from HP? If so, then did the model numbers of the old one match the new one you bought? If the new one isn't an HP power supply, then that could be the reason why it won't charge your battery. Some of the "after market" power supplies will be enough to run the computer, but they aren't all able to charge the battery. It could also be the DC Jack on the motherboard that has gone bad. If you are not familiar with de-soldering a component from a motherboard, then you may want to think twice before attempting it. You will have to get the exact jack that goes to your motherboard, de-solder the old jack, & solder in the new one. Trust me, de-soldering and removing an old jack isn't always as easy as it sounds. You will have to completely disassemble your laptop to do that too, so be sure to keep track of all the little screws and which screws go where. Check out Madhatter Computers on Facebook, or go to the website: www.madhattercomputers.com.
Jul 20, 2010 | HP Pavilion dv7-1240us Notebook
Plug in ac adaptor to Dell inspiron 600m and does
Sounds like you have a broken DC Power jack. This is where the small socket where you attach the AC adaptor breaks loose from the motherboard , resulting in the laptop not charging properly or at all . If you have to wiggle the power jack to get a connection then this is definately theproblem.
Most computer reapir shops can do this for about $100. Or if your handy with a soldering iron and dont mind disassembling the laptop , you can always buy a new DC jack for your make and model off ebay and try to solder it yourself!
If you found this post helpful , please rate my post
Regards
1234s282
Apr 17, 2010 | Dell Inspiron™ 600M PC Notebook
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will not power up suspect mother board shorted out also. Any suggestions
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Dec 01, 2009 | HP Computers & Internet
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
CAN NOT CHARGE BATTERY AND AC POWER NOT WORKING ON MY DELL 600M INSPIRON
the battery could be a bad one or it my be a bad dc jack and would need to be replaced
Apr 28, 2009 | Dell Inspiron™ 600M PC Notebook
Not charging off the power jack
One wrong spark and you'll need a new laptop. Take it to a reputable repair person. A jack is an repair.
Mar 29, 2009 | Dell Inspiron 600M Notebook
Wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Nov 26, 2006 | Compaq Refurbished Notebooks: Armada M700...
Dell Inspiron™ 600M PC Notebook Logo
168 people viewed this question
Clive
Clive
Alun Cox
