Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
Draft inducer blower going bad
I have a Trane XE90 (1994) furnace. The power vent fan is making noise and I am in the process of changing it myself.
The FASCO blower unit is listed as 7062-3956 at 3450 rpm.
My repair man ordered the replacement unit. It's not the same. My unit has a electrical box attached on the side of the motor. The replacement P/N D342094P03 doesn't have that attachment and is listed at 3400 rpm.
His supplier said that is the replacement.
All I need is agree or disagree.
With the internet I can see the numbers and I cannot find anywhere that will support the replacement part.
  • acam4 Jan 18, 2009
    My only thought is that I'm dealing with carbon monoxide exhausting out doors. Some engineers calculated, in the 90's, that a 3450 rpm blower was warranted to exhaust the carbon monoxide from this furnace.
    Now 15 years later I'm even thinking, what's 50 rpm less and so what it doesn't have that electrical box on the side of the motor that I'm not aware of it's function.
    The new furnaces have advanced techniques that can encompass 3400 rpm or perhaps less was my thought process .
    I'll probably wind up using it but had to run thru the if's and and's.
    Thanks
The Fasco book says the correct replacement numbers are as follows:
"7062-3956 = D330757P035 = Fasco # A130" . If the one your installer has needs to be modified to fit, I'd find another installer!
Posted on Feb 01, 2010
  • sprky Feb 01, 2010
    I have similar problem with my Fasco equivalent #A145. I'm pretty sure
    it is a bad motor bearing. Electrical box on the side of the motor
    usually holds the small capacitor the motor needs to run properly. It
    should not be a problem if the motor run capacitor is mounted on an
    external bracket, as long as the rest of the replacement "draft
    inducer" fits perfectly and moves the same amount of air!
    President:
  • 2,692 Answers
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Posted on Jan 17, 2009
  • Thomas F. Schneider Jan 18, 2009
    The electricial boxs seem to be on a lot of the old motors that I have changed out. I am fairly sure that when you open it ,it will only be there as a junction or to change speeds on a multispeed motor.
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Draft inducer fault
Pressure switch is not proving that the inducer fan is running. First check to see if draft inducer fan is running that will be the small black fan that is hooked to the vent pipe. If fan is not running then replace fan. If fan is running then check the small rubber tub that runs from inducer blower blower to draft switch make sure the hole in the blower cage is not stopped up with rust you can clear this with a sewing needle. If this is clear then check the pressure switch with a volt meter make sure it is getting 24 volts to the switch and through the switch. If it is getting to switch and not through switch then replace the switch.
Oct 21, 2014 | Dayton Gas Furnace Heater
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
Turned blower fan on to vent the home. Sudenly it smelled like burning air throughout the house. Turned off the fan. Restarted and no problem. What's going on?
Sunbinder...you will need to do a little troubleshooting. Turn it off again and wait 20 minutes then back on. If no noise or odor. Are you certain that the smell came from the blower. "Thru-out the house is a lot of smell. Listen closely on startup and running....any unusual sounds. ? Which fan are you talking about ? Furnace ? Vent like bath or kitchen ? If you are handy you can check the wiring connections to be sure they are secure and making good contact with tight wirenuts or screws etc.
Jun 07, 2010 | Cross Furnace Draft Inducer Blower 115...
When turning on heat after a period of using air
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
When the furnace comes on after recovering from low thermostat setting, we can hear a loud noise, something akin to a wooden bead that's being blown around inside the unit. Once temperature is reached, the...
Could be correct, or you may have something in your fan that either fell into or crawled into your fan through the exahust duct.Since you have a service contract, have they actually been out to look at it or did they tell you that on the phone. It might be worth removing the fan and clear any forign matter. The problem is the labor to do that would be the same as to replace it. What does your service contract cover??
Feb 24, 2010 | Omega Trane Furnace Draft Inducer Blower...
The draft inducer comes on and the furnace lites as normanl Goes thru its cycle and kicks off. The problems is the draft may not kick on the next time and sticks and the motor gets hot, If I go remove the...
When a furnace is replaced with a newer style unit like yours with an inducer motor, they sometimes use the old vent pipe. These old style vent pipes are transite (light weight cement), the moisture created from your furnace exhaust is caught on the cool transite surface and runs back down into the blower blades or wheel bringing a white mineral deposit with it which causes your problem. The vent should nave been replaced with the heater using a metal vent material. You will need to replace your inducer motor assembly and vent pipe to prevent a recurrence.
Dec 04, 2009 | Omega Trane Furnace Draft Inducer Blower...
Intertherm gas furnace inducer centrifugal switch does not close in time. Blower works but furnace does not ignite
Chances are the draft inducer motor is not pulling enough CFM through the heat exchanger.
That is usually due to either blocked/clogged flue pipe/vent.
damaged, missing or dirty fan blades.
or a motor going bad.
Check those three things first, as they are the usually problem. Other than that, it would be a sticking or bad switch.
If you s-uck on the end of the hose like a straw, while it is attached to the switch and it does not pull in then you are looking at a bad switch/cracked hose issue. If it does, then you are back to the draft inducer motor or it's squirrel cage fan being bad.
These are notorious for rusting and the blades breaking off.
Oct 03, 2009 | Heating & Cooling
Central heater will not heat up to set temp on thermostac
pressure port is plugged pull hose off draft motor and clean port with a paper clip
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
1,711 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
