Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Freezer water leaks into refrigerator - Whirlpool
Model #ET8CHMXKB0 2
Ice builds up in the bottom of the freezer and when defrost kicks on water flows through two holes in the bottom on the freezer and into the refrigerator.
With a $140 technician visit, Whirlpool's Diamond Service diagnosed this leaking problem as a thermostat issue. For another $40, a new thermostat was installed. When the problem returned close to 30 days later -- takes time for ice to build back up -- Diamond Service said they'd have to charge another technician fee for a return visit and new diagnosis because it was past 30 days from installation...not to mention the likely charge of another part. Again it takes it about 30 days to know if a solution will work in this case, so this service philosophy might have us paying Diamond Service over and over.   Sorry to vent, but this is nuts. It brings new meaning to the Whirlpool tagline -- The inside advantage. We're close to $200 in with nothing to show for it but a wet fridge. Any ideas on what I can do to avoid the Diamond Service scheme.
Thanks in advance for your insight. I have the same issue on a Kenmore 106.70267990: water drips into refrigerator, drain line is frozen. It keeps doing it over and over again. I've gotten pretty good at clearing it out, can do it with a hair dryer and a turkey baster in under an hour. Still, it shouldn't do that. Sort of defeats the purpose of a frost free freezer when you have to defrost it every six months.
I'm going to try replacing the thermostat and the defrost timer. They're both on the thermostat tray, which comes off by removing two screws. They're about $30 each ($40 once you've added shipping and all that). We'll see in six months if it's solved the problem.
  • 410 Answers
Here is a quick fix for you. go ahead and clear the drain line AGAIN=). you will need to get a peice of copper wire about 6 inches long, I use a piece of 10 or 12 guage solid copper wire. put one end of the wire into the drain hole then wrap the other end around the defrost heater. what happens is when the unit goes into def. it transfers heat down the wire and keeps the drain clear of ice. good luck peyton
Posted on Jan 20, 2009
Added a heat probe to my fridge and good to go. Thawed out ice build up around drain hole and verified drain is working correctly. Easy install, just hangs off of tube heater and goes into drain. Follow the accompanied instructions with the probe. As always take the necessary safety precautions. Check out Amazon for defrost heat probe 819043. I was able to obtain it locally for same price around $10.
Posted on Feb 11, 2012
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
I have the same problem and have taken the inside back panel of the freezer off to view the freezer coil twice. Both times (months apart) the freezer coil is frozen over and the drain and drain plate are clogged with ice. I defrosted with a blow dryer, cleared the drain and reassembled. All takes about an hour to an hour and a half. I did this to see if it would repeat and now it has again. It is actually a very common problem in freezers and is most likely either the fan (mine is running fine) or the defrost timer. The timer is a classic failure, so I plan to replace mine. They are usually mounted in the lower back compartment where the compressor is and should cost under $50.00.
Jun 04, 2008 | Refrigerators
Cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
May 06, 2007 | Sub-Zero 611 / O Bottom Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
525 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
