Question about Brother LS-2125 Mechanical Sewing Machine
Brother ls2125 bobbin not picking up thread
My top thread seems to be working fine, but it isn't picking up the thread from the bobbin.  I'm just not sure what is going on or even how it's supposed to move in order for the bottom thread to create that loop.
  • justlindainm Feb 01, 2009
    Not only will my machine not pick up the bobbin thread but it wraps around the bobbin when I am trying to see if it will work that time.
You have the wrong size bobbin in ,its to high over the bobbin case causing it to rap around the bobbin.
Posted on Feb 10, 2009
  • 4 Answers
OK...I have an old singer (from 1964) so I am not sure whether you can do this...
I thread the upper thread as directed.
I stick the bobbin in the bobbin assembly as directed.
LEAVING THE SLIDE DOOR OPEN...I, by hand turn the wheel on the right hand of the machine counter clockwise (towards me). I want the needle go down. The thread from the upper part will enter the bobbin area and will form a loop that goes OVER the top of your bobbin to catch the thread from the bottom.
I keep turning until the machine has complete a cycle where the needle has started from the highest point, dropped to the lowest point (thus forming the loop that passes over the bobbin) and returns back to the highest point).
At this point you will notice that the thread is coming for from the bottom of the machine..I use a scissor to pull the the ends of the thread through. To the top. There should be two ends, one from the top thread, one from the bottom. If you dont believe me..jsut use a bobbin with a different color of thread...you will see what I mean..there will be two threads...one the first color and one the second color.
Good luck!!
Posted on Jan 27, 2009
Could my thead be breaking because of the incorrect bobbin size?
Posted on Mar 10, 2010
It worked a few times for me, and then for the life of me I couldn't get the upper thread to pull up the bobbin thread even though I hadn't changed anything. I then changed the pressure setting from 6 to 4 and it has worked fine ever since.
Posted on Feb 09, 2009
My brother innovis machine has a problem. Top thread frays and breaks, not not seem to be picking up bobbin thread properly. I have changed the needle tried a previous bobbin.
Be sure to install a brand new needle--check that the needle eye is the correct size for the thread you are using--a small needle eye will shred heavy thread. It may also help to remove the top thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Try different thread--AVOID old or bargain bin thread. Check that the upper tension is not too tight.
If the top does not pick up the bobbin thread, the machine may be out of time.
Otherwise, there may be a burr or snag somewhere along the thread path that is catching and fraying the thread. Sometimes there is a snag in the bobbin area (possibly the needle plate or hook) that is rubbing the thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
What Causes My Thread to Shred
Fraying Breaking Madeira
Nov 09, 2017 | Brother Sewing Machines
Top thread not picking up bobbin thread
try changing your needle and make sure the flat side is toward the back of the machine. If that does not work then it will have to be retimed
Feb 21, 2014 | Brother Sewing Machines
I have a LS1217 ..it was working fine then I had to refill the bobbin...that went normally but when I tried to see again e the needle thread is getting caught up and not picking up the bobbin thread. I...
have you tried a new needle
try turning the bobbin the opposite direction in the bobbin case
make sure the top thread has not come off the thread take up lever
Mar 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
Brother 1100 threading the bobbin
try changing the needle
rethread the machine top and bobbin
make sure to use every thread guide
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
I am trying the tention,, and topt is fine,,under neat is loose
try adjusting the top tension
make sure the needle can be used for sewing fleece
try rethreading the machine ,make sure each thread guide is used
if you try changing the top tension & the machine doesn't respond to any tension setting then maybe the tension dial needs to be replaced
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is wound correctly
clean under the needle plate & in bobbin area for lint or loose threads
Apr 01, 2012 | Brother Sewing Machines
My White 5500 sews perfectly on the top, but the bottom thread is tangled and messy. I have tried to adjust the tension according to the manual but nothing seems to work. Help!
This is a really common problem especially on side bobbin machines, and the manual will tell you it's a tension problem but it's often a more general thread feeding problem. First make sure you have a good quality thread that isn't old or sticking as it comes off the spool. And more important it can't be too heavy, especially in certain fabrics and with a fine needle. A too heavy thread will cause all the problems you describe.
If your machine uses a bobbin holder and it has a tensioner in it make sure it's clean and well adjusted and has no gummy residue on it. And finally look at the bobbins themselves, I understand older machines work better with metal bobbins vs plastic.
These are very generic solutions but I had similar befuddling problems with a newer Brother side bobbin machine and was tearing my hair out over the thread bunching and Brother support kept insisting it was a tension problem or improper thread routing.
Turned out I was using too heavy a thread.
Since then I picked up an older (1990?) Singer Meritt 4530 from Goodwill for $20, but it's a more expensive top bobbin machine and NEVER bunches or malfunctions. I'm sold on the top bobbin design now, the mechanism inside is more complex but the thread feed from the bobbin is more direct and simple leading to less sewing issues. So you pay more for less headaches.
Jun 01, 2011 | White Sewing Sewing Machines
Bobbin on SE 350
Hi there, this seems to be a common problem with this machine. I have owned mine for a couple months now. The problem seems to be in the threading. The only solution I have found (and others on many forums) is to rethread the machine and the bobbin. I have also re-wound some problematic bobbins as they just maybe did not wind tight enough. Don't delete your patterns, that is not the problem. I have had proffesional patterns turn out a dozen times and then give me problems only to be fine once the machine decided it was threaded properly.
Feb 14, 2009 | Brother XL-3500
Brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Jun 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Dec 27, 2006 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
575 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
