Not easy to understand what you mean with blurred. Could be out of focus or a blurred because of a low shutter speed, shot with the camera in hand. Try switching the camera to Automatic and switch the AF / MF to AF. On the lens the switch that says A M or M/A A, should be in the A setting.
If the pictures are blurred because of camera motion, you need to either use a faster shutter speed or place the camera on a tripod or other stable support.
If the pictures are blurred because the subject is moving, you need to use a faster shutter speed.
If the pictures are blurred because it's out of focus, you need to ensure that the camera is focusing on what you consider to be the subject, not what the camera chooses.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
With blur, the problem could be the camera, but is usually due to the photographer. You can try using flash, decrease the distance to your subject, before you take the picture, hold the camera very, very still until after the picture is taken. If these things fail, the camera might be defective.
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Blurness doesn't happens because of the number of the pixels in the cameras. Is the picture on the computer screen blur/the cameras screen or the lens hole?
I suggest you to set the camera on Automatic station (red camera on the wheel) in day light,try to stay still see how blur the photos are when you are not playing with the parameters. it it's still blurry it could be the pulley block next to the -eyepiece. roll it until it's not blur.
Check to see if your camera is in Macro mode. This may cause blur. Also hit your function/set button to see if it is in digital macro mode.
Make sure your lens is clean.
Make sure you are set to automatic mode and zoomed all the way out. There are several things that may cause blur, the most of which is camera shake. Make sure your Image Stabilization is turned on. If it is, you will see a little hand in the bottom right corner of the LCD screen.
If it's not on, turn it on in the setup (tools) menu.
If your shutter speed is slow, this will cause image blur, but in auto mode, you won't have to worry about the shutter speed, it will be set automatically.
i cannot see clearly on my cam because its blur
blur
how
