Question about Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver
Bit stuck in Bosch PS20 keyless chuck
I have a drill bit stuck in my drill's chuck. The collar won't pull up as usual to release the bit. Advice?
  • Anonymous Mar 13, 2009
    same issue, does anyone know how to get this fixed?
  • 154 Answers
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Can't locate manuel for dw222 chuckless drill and don't have a clue on how to change drill bit or whatever, help, it was my husbands and really need to use it
Keyless Chucks
Open chuck jaws by turning plastic collar with fingers and insert shank of bit about 3/4" into
chuck. Tighten plastic collar CLOCKWISE while depressing spindle lock button (F) on the right
side of the tool housing (Fig. 4). To release bit, turn plastic collar COUNTERCLOCKWISE while
depressing the spindle lock button (Fig. 4).
NOTE: DO NOT DEPRESS LOCK BUTTON WHILE OPERATING DRILL or while the chuck is
moving.
Link to manual:- http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW222&selectedType=2752#
Jun 13, 2011 | Garden
Cant get the bit out of my cordless bosch drill, chuck seem to be jamed and wont open
what you can try is to spray penetrating fluid on the chuck collar, jaws. Next if you have a GOOD pair of gloves hold the collar and then using the drill motor try and loosen the chuck. If you have a vise with a pair of soft jaws without clamping too tight you can try the same thing. The main purpose is to let the drill torque loosen the chuck collar to release the bit.
Apr 01, 2011 | Bosch Drills
How do i fasten the the drilling bit in the machine ?
For the pictured drill motor, you put the bit in and use a "chuck key" to tighten the chuck onto the bit...
If the photo is not your machine but you have an SDS type chuck, you insert the bit, pull back on a collar and twist the bit until you feel it engage and release the collar. When seated properly you cannot pull the bit out without pulling back on the collar.
Dec 10, 2010 | Makita & 1/2 Inch Drill
Can you give me step by step on how to change drill bits on the Mastercraft Souce One 18V Cordless Drill.
pull the collar on the front forward and insert hex end of bit in and let collar go back. this locks the bit in.
Aug 29, 2010 | Bosch PS20 2 Factory Reconditioned 10.8V...
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
How to fit drill bit to drill
it depends what chuck (the part the drill bit goes into) on the old ones you had a chuck key that slots into the hole on the side and connects to the teeth to tighten the chuck around the bit, keyless chucks are tightened by hand instead of the key and the SDS have a collar that pulls down, you have to turn the bit so it then slots in then just release the collar to fix it in place good luck!!!
Jul 30, 2009 | Drills
I have a drill bit stuck in my bosch 10.8 cordless litheon- it is
without having the exact model number for this tool I have in the past removed the outer collar on the quick release holder. After that you take out the small steel ball and the bit would come out but If you can provide the model I will look at it and see and call a friend that is a Bosch Authorized Service and see what they do in this case.
Jan 17, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver Logo
1,499 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
