Question about Jet 3 Ultra Power Chair
I need to replace the battery. where can i get a new one?
All of the sudden the battery for my power chair died while i was charching it and then it wouldn't turn on anymore, so i need to buy a new battery but i have no idea where i could get a new one from.
    Problem Solver:
  • 16 Answers
Well, if you purchased it thru a certain company, that would be were you can get a new one, if you didn't you can try different wheelchair providers like Hudson Home HealthCare, and Burke Medical, (these are locally my way) but maybe they can tell you where to find the new batteries..or where to purchase a new one.
Posted on Mar 06, 2009
Pronto MC1 chair stopped running; battery plugged in
charge48 hours at first then at least 2 hours for 1 hour of use.- 4 years is a long time stored batteries may be bad
Nov 22, 2012 | Invacare Supply Group Pronto M61 Standard...
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
Mar 16, 2011 | Jet 3 Ultra Power Chair
I just gave my mother in law the jazzy 1103 ultra power chair... when you put it on.. the lights flash and the chair creeps along.. it happened all of a sudden.. it wont speed up.. this was donated so I...
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Sep 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The chair suddenly lost power and now the lights flash continuously. The chair won't take a charge. A repairman tried fixing it at a local shop and said he put a new battery in and it sizzled. Now he is...
If he put in the batteries (2) properly, they should never sizzle. Some will emit a very minute spark when the final connection is made, but that is normal. There are fuses coming off of each battery to the power controller that will blow at 40 to 100 amps or so, depending on the chair; these will blow before the chair frying, or the circuit breaker will trip, or the controller will fry and all will be quiet on the chair, so I am going to say that the batteries weren't properly hooked up, otherwise on of the above items would have shut everything down. Continuous flashes indicate trying to start the chair while it is still on the charger, or with the joystick off-center. Make sure it is unplugged and notohing is resting against the joystick. If it's still a no-go, then you have either a joystick issue or controller issue. You will need to test those by replacing with known good controller/joystick, which a dealer should be able to do for you. Good luck.
Jul 17, 2009 | Jet 3 Ultra Power Chair
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
New battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Mar 03, 2009 | Jet 3 Ultra Power Chair
We have a Jazzy 1113 Power Chair. The chair is fully charged, but does not move. What might be the problem?
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Dec 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Nov 10, 2008 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
324 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
