Question about Chicago Pneumatic 1/2" Air Impact Wrench
My 1/2" CP air wrench just blows air thru when I pull the trigger
I worked fine for years, I always kept it oiled, now it just blows air thru when I pull the trigger, does not turn. Thanks, Doug
  • 14 Answers
I have ran into this many times, even though you keep it oiled dirt can and will get inside. what you need to do is unscrew the 4 alen head bolts and pull the nose off. You will see a shaft that looks kind of like a crankshaft with 5 or 6 flat carbon fiber plates sitting loosely in groves around the shaft. pull those out and clean them with solvent and check them for damage or wear. clean the inside of the gun with solvent or brake cleaner, reassemble and it should work fine. If the plates need replaced then you should be able to order them from a tool supplier,and they are not that much.
Posted on Jan 17, 2009
CP 734 Trigger Broken
If you are still looking for this part I would call power tool repair at 330-630-0022 and order that part number. From the breakdown it seems you have the correct part number
Jul 24, 2012 | Chicago Pneumatic 1/2" Air Impact Wrench
My CP impact wrench run fine when not removing a bolt. When removing the bolt it turns it a few rounds then stops
Try a good cleaning with diesel fuel. Keep adding diesel into air inlet until the fuel comes out clean (add diesel then connect air to blow it out) . Once clean, add several drops of oil and retest. If it works better but not full power, try another cleaning with wd40 and retest. Good luck
Oct 16, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
My cp 734 air wrench wont turn just blows air through the trigger can anyony help??
It will require new seals fitted by a repairer. It's not a DIY
Please rate my help++++hanks for using FIXYA
Jul 30, 2010 | Garden
Wont work in remove direction just blows air
fill it wit oil hold in triger and flick between forard and reverse should free up the vains inside
Jun 29, 2010 | Craftsman 1/2" Impact Wrench
Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Oct 18, 2009 | Craftsman 1/2" Impact Wrench
The 734 cp impact wrench has not been used for a couple of years and appears in excellent considtion however, I do not remember how to oil and/or remember the impact ratings using the dial; is there a...
Put 4 or 5 drops of oil into the air line opening. Connect an air supply and burst the trigger a few times. The settings are 1-less 4 more. It's all up to the application and they are not specific settings.
Oct 10, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
It does nothing
Make sure that you have at least 50 psig of air pressure before you attempt to troubleshoot your impact. 70 is better, 90 is perfect. Impact wrenches are powered by internal sliding vanes, which can sometimes stick. There are a couple of ways to get it going again. Try 1 before going to 2, etc,:
1. Spray W-D 40 or a similar oil into the impact, while you are holding the trigger down. Give it a good shot. Connect the hose and pull the trigger. Tap the sides of the gun with a plastic hammer to help free up the vanes. Repeat. Normally, this is enough to get you back running.
2. Place it in a bucket and cover the gun with W-D 40. Work the anvil end and trigger to work the oil deep into the gun. Ley it soak 1 hour, and repeat the process, working the oil in, and the air out. Remove it from the oil, and drain the oil back into the bucket by holding the trigger down. Hook up the air, and blow it out.
3. Remove the cover on the head that covers the vanes. Make sure that the vanes will slide freely, and that all gaskets and "O" rings are in good condition. If you note any dry areas in the inner parts of the impact, lubricate with W-D 40, and reassemble.
4. I'm all out of ideas.. If that didn't fix it, I'd go get a new one.
Best of luck, --W/D--
Aug 13, 2009 | Air Tools & Compressors
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
Chicago Pneumatic  1/2" Air Impact Wrench Logo
2,665 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
