Question about Hitachi Office Equipment & Supplies
The hitachi lcd cx445 came on made a noise and went off/no power
The lpanel ights were blinking red until I changed the lamp time and then they went off a week later There is no power now.
ctf1800
  • 4402 Answers
SOURCE: Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: Lamp Nec mt 1050
i have a mt1020 and the switch for the lamp cover might be the problem,find the switch with cover off. push up with small screwdriver, if this works just add some tape to the arm on the cover that pushes the switch up...
Posted on Feb 01, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
  • 13433 Answers
SOURCE: mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Posted on Mar 14, 2008
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Mod 50v500. went black while watching with a popping noise. will not come on, power light and lamp and temp lights blink.
A good idea is to locate the lamp door; remove and examine the lamp--if it is exploded( looks like old school flashbulb) it is your problem.
This part is customer replaceable--If you have your owner manual instructions will be in it. If you do not have owner manual Google model number with "lamp replacement instructions"
If this does not work, let me know and I will try find them for you--the POP suggests the lamp went out.
SD TECH
Jan 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Oct 18, 2009 | Hitachi 50V715 50" Rear Projection...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Help
This could be your lamp is bad..
Change the lamp.
Sep 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi VS810 Turns off by itself
the high voltage supply for the lamp may have blown.
cheap bulbs don't always have the correct rating.
made in china?
Feb 16, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
My lamp light is blinking after changing the lamp out
maybe you have lost contact at the lamp circuit! or check the lamp circuit.
Oct 02, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
37 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
