Question about NEC MT1060 Multimedia Projector
NEC MT1060 DVI Projection problem Problem
Hello Gang, when I hook up my projector to show a movie using an HDMI to DVI cable from a Samsung 1080PT DVD player the video starts to show as the DVD splash screen says loading, then it switches to show PLAY but as soon as the trailers start the screen goes blue and the screen shows the source bar - DVI Input. After several reboots of the DVD player and power ups of the projector it still occurs. Any suggestions or is my graphics card shot or going bad. I have swapped out cables and even DVD players to no avail. Thanks in advnace
  • tgalliott Sep 13, 2008
    Got the same problem. Tried both hdmi outputs from a 1080P sony blue ray player and a toshiba 1080i player. Neither of these work. With the toshiba I just get a flash of the dvd and then blue screen.
3 Suggested Answers
SOURCE: pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Posted on Oct 20, 2008
RyanFanMan
  • 342 Answers
SOURCE: mt1065 NEC projector HDMI to DVI adapter no
did you buy that adapter from radio shack if so then return it and look at somewhere like staples or best buy they can help you
Posted on Jan 02, 2011
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: http://www.nec-display.com/dl/en/pj_manual/lineup.html . The direct link to the manual for the MT1060 is http://www.nec-display.com/dl/en/pj_manual/mt1065.html .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
How can I hook up my projector to my ps3
If your projector has a HDMI connection or a DVI.
if you have a HDMI plug it straight in and select either HDMI1 or 2 as your input
or if has DVI you will need a DVI to HDMI convertor.
even if you have VGA you should be able to do it but you getting to many wires involved then but heres how any way VGA > VGA to DVI > DVI to HDMI
Jan 08, 2014 | NEC NP400 Projector
Connection computer
if your projector has a HDMI connection or a DVI.
Mitsu x400bu gives coprright indication when i go from hdmi todvi
Firmware update, yes or use component video. HDMI has embedded copy protect and is really an aggravating connection. Consider this, hdmi's benefit is embedded audio, your projector does not need this. Component video will meet you needs because the projector is not real high on res. Good luck
Mar 24, 2009 | NEC Mitsubishi LVP X400BU Multimedia...
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
NEC MT1060 Multimedia Projector Logo
91 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
