Question about Minolta Maxxum 400si 35mm SLR Camera
Aperture ring control
I got this camera from my sister in law 3rd hand she never got a chance to even run the 1st roll through it before getting a digital and giving it to me. i put a new battery in and a roll and snapped a test shot and got a HELP message i checked out a few things and came up the conclusion that the aperture ring control is stuck problem is i dont know how to begin repairing it i believe he i can get the part and a manual i can do the job myself
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Minolta Maxxum 400si is locked up
link to your manual, it tells us that we have a winding motor problem, I would do as you have done, so I would ensure that batterys are in great shape, the only other thing I could suggest is to try to turn the winding motor by hand in case it is just locked up. Failing that I presume the motor has died and needs replacement.
Posted on Dec 05, 2007
Steve5
  • 423 Answers
SOURCE: Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Posted on Mar 16, 2009
How do you use manual aperture ring
What make and model camera and lens?
With some cameras and lenses, you turn the aperture ring to select the aperture. With others you lock the ring at some setting and control the aperture from the camera body.
Oct 05, 2014 | Cameras
Error message
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
The aperture ring is the one with a bunch of numbers on it such as 2.8, 4, 5.6, 8, 11, 16, and 22.
Jan 16, 2014 | Nikon D60 Digital Camera
Fee error on d300 with Sigma lens with aperture ring
Turn the aperture ring on the lens to its smallest setting (largest f/number) and then forget it's there. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Oct 13, 2012 | Nikon D300 Digital Camera
What is the little red button on the lense on the end that screw to the camera that has a red L
That's the aperture lock lever. On many Nikon cameras, the lens needs to have the aperture ring turned to f/32 and locked in place. You then control the aperture from the camera body, the same way as on a lens without an aperture ring.
On older Nikon cameras, you unlock the aperture ring and control the aperture by turning the ring.
Jan 30, 2012 | Nikon 's 80-400mmhigh-power zoom lens...
Hi, I have a Nikon D60. Somehow I locked aperture at highest number. Even with Manual setting, it does not let me change aperture! Please help
The lens is supposed to be locked at its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring. For example, in aperture priority mode (A), simply turn the command dial. In manual mode (M), hold down the exposure compensation button while turning the command dial.
That was for a lens with the electronics to communicate with the camera. If you have a purely mechanical lens, you must shoot in manual mode and control the aperture by turning the ring on the lens. There should be a small orange slide near the aperture ring, Slide it toward the front of the lens to unlock the ring.
If you need more help, please feel free to reply to this post. Please specify the lens when you do.
Aug 13, 2011 | Nikon D60 Digital Camera
The f stop say ee
You're apparently using a lens with an aperture ring. Turn it to its smallest aperture (largest f/number). You control the aperture from the camera body, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, clean the electrical contacts on the back of the lens and in the lens mount.
May 14, 2011 | Nikon D200 Body Only Digital Camera
Blinks FE E ..what does that mean?
This normally means that the lens is not locked at its smallest aperture. Are you getting this with the 18-70mm lens? If so, try cleaning the electrical contacts, both on the back of the lens and in the mount on the body.
If you're getting this on a lens with an aperture ring, it's perfectly normal. Simply turn the ring to its smallest aperture (largest f/number) and lock it. You can let the camera control the aperture, or control it from the body yourself, the same way as on a lens without an aperture ring.
Mar 12, 2011 | Nikon D70s Digital Camera
FE E code????
You're using a lens with an aperture ring. Turn the ring to set the aperture at its smallest opening (largest f/number) and lock it if the ring has a lock. You can control the aperture from the camera the same way as with a lens without an aperture ring, or let the camera control it.
Mar 03, 2011 | Nikon N65 35mm SLR Camera
How do I change the aperture on my N6006? And what do I change it to? I keep getting a fE E error message.
That depends on the exposure mode.
In any of the P modes, turn the aperture ring on the lens to its smallest aperture (largest aperture) and lock it. You control the exposure by turning the command dial on the camera.
In S mode, lock the aperture ring as above. Turning the command dial changes the shutter speed and the aperture changes to match.
In A mode, control the aperture by turning the aperture ring on the lens and the shutter speed with change to match.
In M mode, control the aperture by turning the aperture ring on the lens and control the shutter speed by turning the command dial.
If the lens doesn't have an aperture ring, you can only use the P and S modes.
Nov 14, 2010 | Nikon N6006 35mm SLR Camera
Nikon n55 film camera
You must have your lens set to the minimum aperture setting for this camera to function. I.E. f22,f32. The aperture ring moves a small tab on the outside of the mount ring when in that position.
Jan 13, 2008 | Nikon N55 35mm SLR Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
21 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
