Question about Microsoft Xbox 360 Console
Three red flashes
I used one of the xbox fixes, it worked until I put it back togeter. What did I do wrong?
    Scholar:
  • 33 Answers
When someone say that his/her Xbox is having 3 red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Mar 05, 2009
  • 344 Answers
I have found that some machines cannot be placed verticle after making that repair. Also, you need to completely wait till the machine is cold again after you flow the solder, then put it back together. Thanks!
Posted on Jan 17, 2009
Everytime i turn my xbox360 on its flashing red like it the red ring of death
1 Red Light
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights
One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights
If you see three flashing lights, you are experiencing the infamous Xbox three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the Xbox 360 warranty.
If you want to try to fix the problem yourself then you can see reviews of guides that we recommend to show you step by step how to perform the repair.
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Mar 22, 2011 | Video Game Consoles & Games
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
Three rings of death
Your system will need the 3 red light service. The 2 red lights flashing indicates overheating. We can fix this for you if interested email for estimate
xbox360fixer@verizon.net
Thanks
Jan 13, 2009 | Microsoft Xbox 360 Console
3 red lights on xbox360 and screen problems
Hi there!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 3 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 3 red lights. Even before you get the 3 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 3 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that’s all.
Cheers!
Dec 21, 2008 | Microsoft Xbox 360 Console
3 red flashing lights
if all three except the upper right are flashing then i am afraid u have the RROD-red ring of death..call microsoft and they will send u a replacement after u describe the problem..i had three such replacements!!!
hope u get urs running ASAP!
Nov 01, 2008 | Microsoft Xbox 360 Console
3 flashing red lights
Hi ! This is call the Ring of Death. You have to send your Xbox back for a free repair or an exchange. Those 3 lights mean that their is an internal problem whit your console and Microsoft have put a new waranty system that allows you, for 3 years since you have buy the console, to return it and the gonna repair it or exchange it for you, and all that, for free
Aug 05, 2008 | Microsoft Xbox 360 Console
Three red rings
There are repair guides out there that will fix it - but you had better find the right one for the job - here's a website that will help with that:
www.BestXBOX360RepairGuides.info
Good Luck!
Jul 26, 2008 | Microsoft Xbox 360 Console
3 red lights flashing
well you can call the xbox assitance and they will tell you to put in the xbox serial number, your state, adress, etc. you have the 3 rings of death, so what they will do they will send you a box for you to put your xbox and send it back to get it fixed, this only works if you have the 1 year warranty, if you do they will fix it for free, if you dont you have to pay, but its worth it.
Jul 07, 2008 | Microsoft Xbox 360 Console
Three red lights flashing
When someone say that his/her Xbox is having 3 red lights Flashing problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Apr 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
