Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
Display suddendly went "off " on Uniden TRU9488 base unit
How to reset ?
  • Anonymous Jan 19, 2009
    "Out of Range" is displayed on one of my handsets and it can not make or receive any calls..thanks!
Unplug main base for a minute then put each phone back in main base
Posted on Jan 18, 2009
Light stays on in the base unit and light flashes on handset. No messages--all have been retrieved.
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
May 15, 2015 | Uniden TRU9488 Corded/Cordless Telephone -...
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
My uniden axis phone when dead ysterday. There is no information on the display just the light is on
My Uniden digital powerMax 5.8Ghz hand phone went dead and does not want to take a charge, although the base unit red charger light is on.
Mar 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
I have caller ID with phone company and we recently, in our area went to 10 digit local dialing in our area.My Uniden cordless phone tru9488 still only shows 7 digits on the call display. one other phone...
Somewhere, like on pdf page 48 there's a note about 7 digit dialing. In MENU GLOBAL SETUP AREA CODE it displays yours. Press DELETE and OK and it goes away.
Here's the manual: http://www.uniden.com/pdf/TRU9488om.pdf
Carl
Oct 23, 2008 | Lands Phones
OU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Jan 28, 2008 | Uniden TRU9488 Phone
Uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
Jan 12, 2008 | Uniden TRU9488 Phone
Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
Resetting Handsets
SYSTEM RESET menu
appears.
confirmation tone.
Dec 29, 2007 | Uniden TRU9488 Phone
E4 error code
I called Uniden about the same problem.  They say it is a code that means it is defective base unit.  I had purchased it within one year and they will gladly send me a new one.  I don't know if they will offer anything beyond the one year mark.
They say it was a spike in the power lines that causes this error.
Oct 09, 2007 | Uniden TRU9488 Phone
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
160 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
