Question about Hyundai ImageQuest P910 Plus (White) 19 in.CRT Conventional Monitor
Off mode Monitor is in off mode How do I fix this.
  • Anonymous Apr 20, 2009
  • Hyundai Master
  • 12,061 Answers
I would suggest that the Power Supply has gone faulty.. A common problem these SMPSU's cause all sorts of problems.
Posted on Jul 24, 2007
How to fix the monitor from entering into power saving mode when i switch in the computer. i am not able to switch on.
The monitor usually goes into the "power saver" mode when there's no signal from the computer. I'm pretty sure it isn't a problrm with the monitor. Try replugging the cord from the computer to the monitor, at both ends. If it still doesn't work, try a new cable.
You could make sure nothing's wrong with your monitor by plugging in another monitor or projector. You should still have the same problem.
If this doesn't fix your problem, add a comment to this question.
Aug 27, 2014 | Dell Computers & Internet
My monitor on my gateway mid tower goes straight to power saving mode so I can"t log on
Hi, if the monitor stays on "saving mode" it means you have some bad capacitors inside the monitor, so you have to get it fixed. If you connect another monitor and you still get the same thing, it means the display's resolution is out of range. So restart safe mode and reconfigure it. I hope this helps.
Apr 26, 2010 | Gateway GT4016 Desktop PC
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
My monitor is stuck in power saver mode
There is something electrically wrong in your monitor which an electrician can identify and fix. There is nothing to worry, some capacitor might've shorted out. It'll be fixed cheaply. Hope this works.
Aug 22, 2009 | Dell E176FPC Monitor
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and...
open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Dec 21, 2008 | Computers & Internet
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Oct 28, 2008 | Samsung 226BW Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Hyundai ImageQuest P910 Plus (White) 19 in.CRT Conventional Monitor Logo
85 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
