Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Housing Jammed
I cannot get the housing out of my machine....it says "push" and it's always a small movement, but one side is coming out and the other is jammed. Help.
    Welcome Back:
    Visited the website for 2 consecutive days.
Http://216.244.99.185/custompages/Manuals/Incanto%20RS%20SBS.pdf
Here is the manual. Try page 11. Did you take the drip tray out first? You move the "push" part to the right and while doing so use your other hand to pull the whole unit out. The "push" part is a small movement.
Posted on Feb 02, 2009
I have lost my saeco incanto manual and I forgot how to descale it,which buttons to push
The button looks like little small triangles.
Here is the link to download the manual. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
May 30, 2011 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Deluxe brewunit jammed
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Saeco incanto rondo boiler reset
There are thermostats (2) on the side of the boiler colsest to the side of the machine. There is a reset button on each between the wires terminals. Push both.
Dec 11, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
English manual for a saeco sup 021 - decalcifying
You can download it from this link:
http://www.gaggiaparts.com/user/Incanto%20Classic%20MANUAL%20USA[1].pdf
Nov 14, 2009 | Saeco Incanto Classic Espresso Machine
How do you get the float out from the water tank on a Incanto S Class Saeco Coffee machne
On most of the machines there is a small plastic square plug above the float, if you remove that the float will come out.
Sep 09, 2009 | Saeco Incanto Classic Espresso Machine
Saeco incanto deluxe gear or splinbe drive out 180 degrees.
Thats a tough one without seeing the unit, use the pic below to help align the unit.5101bd5.jpg
May 31, 2009 | Saeco Incanto Classic Espresso Machine
Our saeco incanto turned off for no reason-won't come back on.
Push on the right upper side of the door and see if the light comes on?
May 18, 2009 | Saeco Incanto Classic Espresso Machine
No power to Saeco Incanto Rapid Steam
If you have a round boiler on your machine, then you have two automatic fuses on the right side of the boiler close to the chassis, there are wires going to these fuses and in the middle of the fuse you have a plastic pin you have to press down, you have to these on both fuse.
If you not have a round boiler then you have a wire with a black holder, the wire mostley have a blue color.
Best regards
/Mirran
Feb 02, 2009 | Saeco Incanto Classic Espresso Machine
Small leak from the bottom right side (when looking at the machine) of my Saeco Incanto Sirius Espresso Machine when being operated. After two or three cups of coffe are made, need to move machine to the...
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part.
Per
Oct 13, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
206 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
