Question about HP PhotoSmart 7550 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
If I try printing an 8x10 photo image - the printer will "jam" (I use quotes because the printer does not appear to think it's jammed - rather it thinks it is done). It always happens when the job is about 90% complete. The print just stops - the ink cartridge returns to its cradle but the paper doesn't get spit out - it gets held on to. Printing full color papers from the web has no problem
  • arlington_ho Jan 19, 2009
    Thanks a lot - I will give that a try!
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 19, 2009
Will the hp photosmart printer use 8x10 photo paper?
You will have to check the equipment driver itself. While attempting to print, try changing the page size (go to page setup). This will give you an idea.
Sep 07, 2014 | HP PHOTOSMART 7520 E-ALL-IN-ONE
HP Photosmart 7550--"double vision"
There are known issues if you are not using geniue hp cartridges.
Can you try the printer in another computer to see if its a issue with your computer or a internal printer issue?
Aug 11, 2008 | HP PhotoSmart 7550 InkJet Printer
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
How do I reduce an 8x10 photo to a 5x7 photo?
Are you using windows vista? If you are, here's what to do. Open the picture using windows picture viewer (right click the pic., click "open with" then click "Windows picture viewer" when the window opens, on the right, click "full page photo" (the top one) then click 2options" then "printer properties" Under "paper size" click " 5"X7" Borderless or 126X178 Borderless. Click "OK" then click "Print"
Et voila!
Hope this helps.
Jan 11, 2011 | HP PhotoSmart C4180 All-in-One Color...
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
The kodak gloss paper gets jammed in my hp photosmart 7350 printer towards the end of printing photos
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Nov 24, 2009 | HP PhotoSmart 7350 InkJet Printer
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
May 14, 2008 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
145 people viewed this question
Seeker5211
Seeker5211
