Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Dell Dimension 4600 - unable to connect to internet.
Have a working PC on the same connection, When I move the cable to new PC (Dell dim 4600 running XP Profesional version) is not working. I use Comcast High Speed Internet and have not been able to install nor create a new connection from new machine. I looked at the adapter (Intel (R) PRO/100 VE Network Connection in the device manager but it seems to be working properly, however under other divices the Network Controller says that divers are not installed.
Gimme the error msg...
Posted on Jan 18, 2009
I need an ethernet controller driver for my dell dimension 4600 desktop
Well that is a problem. You can go to "support.dell.com" to download the drivers, however since you can't connect to the internet you will need to use a friends computer and download it.
Aug 13, 2012 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 won't connect to the internet and has a solid orange internet light, help?
go into internet options and connections and tell it to never dial a connection see if that helps
Jul 12, 2012 | Dell Dimension 4600 PC Desktop
I have a 2003 Dell Dimension 4600 and the network adapter is testing fine. However I am unable to access broadband internet and email through a wired USB/Ethernet connection to external modem. Both the...
the hard wired connection to the modem could be a system configuration issue, the cable has gone bad, or the modem is having connectivity issues with the service.
if your optical drives are not working physically, then you can't really fix that. if they just arent responding properly or Windows cant detect that they are there, then you may need to reinstall the driver software for the drives. which can be found on the Dell website or the manufacturer of the optical drives.
yes you can set up a wireless connection with a USB adapter but the modem also needs to have wireless capability in order for you to create the connection.
there are external USB optical drives available. so you can purchase a usb connected CD/DVD drive or burner. they shouldnt be very expensive nowadays.
Apr 22, 2011 | Dell Dimension 4600 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I recently moved and when i went to start up my computer it takes me to a blue screen say memory is being dumped. Prior to that though there is a screen saying that a "0 drive" can not be found. Any idea...
Your 0 Drive is the main hard disk drive in your computer. That is where Windows is installed. If the pc doesn't see it, it cannot start. If you've moved, the hard drive cable or power connection may have come loose. You can try opening the case and reseating all connections and see if that works. If not, it's possible your hard drive is damaged and not working.
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 wi-fi shows good signal and it says it's connected to internet but in status it does not show activity so I am unable to got into internet.
Is your internet working on other computers in the house? Try reseting your router, if you need info on that let me know.
Oct 22, 2009 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when...
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
Adding Dell Dimension 4600 to existing wireless network?...
Go to Staples and purchase a Linksys USB wireless-G (only G needed - the new "N" protocol is overkill) adapter (~$60.00). Insert the Linksys CD and follow the instructions. When prompted, plug the USB adapter into the Dell (frt or back) doesn't matter. If his "roomies" have security enabled on their router, you'll need to know the level, password/passphrase, and the network name that they assigned.
Good luck.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
Driver problems
JPWatson, This link will take you to the drivers for your Dimension 4600 with Windows XP: http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_P4_4600&os=WW1&osl=EN As far as the PC showing you already have a connection I would ignore that for now. Just download the appropriate drivers from this Dell page including the network interface card drivers and install them first. After you have rebooted and verified that the hardware devices are working correctly then start troubleshooting your Internet connection if it is still necessary. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 21, 2007 | Dell Dimension 4600 PC Desktop
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
121 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
