Question about GE WWSR3090TWW
GE WASHER WJSR 2080 T2AA WASHER KNOB JUST SPINS
THE KNOB DOESN'T PULL/PUSH AND JUST FREE SPINS, DO I NEED TO REMOVE THE BACK METAL COVER UP TOP W/ THE 4 SHEET METAL SCREWS AND STAR NUTS ON TOP TO REPLACE THE SWITCH, I CAN'T GET THE KNOB OFF BY JUST PULLING
  • 91 Answers
Got to remove top to get to the switch
Posted on Sep 01, 2009
GE washer wjsr 2080 won't spin out
replace the belt easy fix and cheaper than bying new
Mar 06, 2013 | Washing Machines
How to open the front or top of a GE WDSR 2080 washer
you need a thin metal puddy knif to pop the clips in the front top about 2 inch's in on bolth sides and the whole front comes off. then you can remove the screws to remove the top
Oct 30, 2009 | GE WDSR2080D Top Load Washer
Ge wpsq3120t2ww I have a broken control knob, how do i replace this?
Knob(s) on left side of machine just pull off. Make sure the metal D clip comes off too. Push new knob on.
Timer knob: Pull knob out and remove nylon clip off back side of knob. (use a thin screwdriver to push it off, or a thin needle nose plier to pull if off) then knob pulls off easy. Push new knob on with clip already in place. Easy.
Jul 08, 2009 | GE Profile WPSR3120WWW
Removing the Push-to-turn-on knob
if you pull on the knob it will come off it has a metal clip that is pretty snug on the stem but it will come off, you still have to take the cack cover plate off to get to the switch and do the actual replacement
May 29, 2009 | Kenmore 22422 Top Load Washer
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Timer knob spins when pushed in. unable to set wash cycles
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2009 | Washing Machines
Timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Dec 08, 2008 | GE WBSR3140DW Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Aug 02, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
729 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
