Question about Lexmark X4270 All-In-One InkJet Printer
Cartridge error I have a lexmark 2600 3 in 1 and when I go to print, it tells me that I am missing a cartridge. I am not. What do I do?
  • Thomas F. Schneider May 11, 2010
    Reinstall the cartridge. Clean the electricial contacts on it and the machine with a pencil eraser.
  • Lexmark Master
  • 684 Answers
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Posted on Jan 19, 2009
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Feb 12, 2018 | Lexmark X5270 All-In-One InkJet Printer
Test page prints fine alignment problem
Try to re-seat your cartridges into the printer. If the error continues, try to do the Alignment function using the printer software on your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align Cartridges. Your printer will then print a page that will help align the cartridges.
Mar 04, 2012 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X4270 gives an error message...black cartridge missing. It is not missing. what is the problem
Make sure you are using genuine Lexmark black cartridge. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try to reinsert your black cartridge and make sure it is properly seated in the cartridge carrier. If error comes back up right after placing it in the printer, then it could be a faulty cartridge. Try to replace it with a new genuine Lexmark cartridge. If you are already using a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
My printer is a lexmark 2600. i bought a black ink only. when i wanted to print, its not working. it said that i have to alignment it first. i did it already many times, but it's still not...
Some of the Lexmark printers have a sensor that looks for the cartridges and if one is missing it may not print.
The first thing you could try is to reload the Lexmark software from the CD that came with the machine and see if that works. If it does not, you may have to have a cartridge in the color slot to make it print. You could try an empty color cartridge in the slot if you cold find one.
Good luck................Pete
Jul 15, 2011 | Lexmark Office Equipment & Supplies
My lexmark 2600 printer is not finding my color cartridge. they keep on telling me cartridge is missing and to install the cartridge, I repeatedly take out the cartridges clean them and re-install them....
You can try the following,
  • Take out the color cartridge, you will see golden points at the back of it
  • Use soft lint free cloth to clean the points
  • You will also see some golden points on the carriage, where the cartridges are placed
  • Clean the circuit points on carriage with a soft lint free cloth
  • Place the cartridge back and try to print
  • If it still don't work, you can try replacing the cartridge
Causes: Dirty contact points (Golden circuit points), Carriage gone bad, Cartridge gone bad
Regards,
Shrey
Jun 05, 2011 | Lexmark X2600 InkJet Printer
My Lexmark X2670 has stopped printing on my MacBook and I receive the following error message Missing component: /Library/Printers/Lexmark/Drivers/.Resources/2600 Series Color 2.lut How do I fix this
go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "2600 Series Color 1.lut" file. Duplicate it and change the name to 2600 Series Color 2.lut close the folder, and shoot a print, it should work.
Mar 07, 2011 | Office Equipment & Supplies
Can't print black and white only with Lexmark 2600!
Hi MikeC,
Most of the time this is due to the black cartridge being out of ink. The Lexmark uses all the colors to create black when the black ink cartridge runs out, but won't let you print black because it is essentially saving ink.
Hope that's the reason and it isn't the printer failing. Good luck! :)
Sep 23, 2009 | Lexmark X2600 InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5250 Printer
chech to see if the cartridge slot locks down the tab that locks the cartridge have been known to break. or run a maintenance check and clean the printer heads.
Sep 27, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
