Question about Procom ML300EBC Heater
I would like to how many hours will a 20lb. tank of propane last in my procom ventfree 6000btu radiant heater?
  • Procom Master
  • 3,077 Answers
3 maybe less
Posted on Jan 17, 2009
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
My heater is one year old my igniter has stoped working it is a procom 6000btu do they have battery where
There is no battery. Be sure the wire connecting the piezo crystal to the spark wire is attached. Sometimes they fall off.
Feb 12, 2015 | Procom Heating & Cooling
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
How many hours can I get from a 20 lb. propane tank on a Pro com 45,000 btu patio heater?
approx 380000 btu in bottle
380000 / 45000 = 8.44 hours running on full.
Oct 06, 2009 | Procom DPL400HA Patio Heater
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
ProCom VentFree Natural Gas 30,000BTU Garage Heater
first you gotto see IF a changeover is possible! do your instruction manuals say it can be converted?
Jan 12, 2008 | Heating & Cooling
Procom ML300EBC Heater Logo
133 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
