Question about Linksys Wireless-G WUSB54G 802.11g/b
Still working on onboard lan
Can't figure out where to install new drivers
    Scholar:
  • 68 Answers
Assuming you know how to get to the router, select the Admin tab, then select Firmware Upgrade. On the next screen give it the filename and location where you stored the upgrade.
Posted on Jun 06, 2009
I can't activate the onboard LAN Eternet on the P4P800S-X motherboard
Have you got the the chipset drivers installed?
If 'yes', and you have also got the lan drivers installed, then in BIOS settings, make sure the 'onboard lan' isn't set to 'disabled'
Aug 26, 2012 | ASUS P4P800S-X Motherboard
P5ld2dual core onboard lan disabled but wont boot
This is either a driver problem or a "hard" hardware problem. When you are in safe mode you should remove the drivers for the onboard lan and the wireless USB. the most likely cause is the wireless stick. So try re installing the usb drivers again from a different source.
Jul 19, 2012 | ASUS P5LD2 Motherboard
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
I have a IBM thinkcenter 8123 model. I can't install lan due to lac of suitable driver! pls help me!
Go into the bios on your computer and shut down the onboard LAN, find a 3com or realtek LAN card and install it, windows has the drivers build in for most 3com cards, then you go to IBM site, download the drivers you need for the onboard LAN connection, remove the 3com card let the computer boot up, and when it asks for the driver point it to where you downloaded the drivers for the onboard LAN.
Jun 18, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Dont have motherboard cd,m not able to find LAN Drivers on net
You have 2 choices. 1. Call Intel tech support & see if they can find a solution for you or 2. Install a standalone ethernet/wireless card, depending on your setup and disable onboard LAN. I had to go the 2nd route as my onboard LAN wass not compatible with Windows Vista. Hope this helps.
Dec 24, 2008 | Intel D845GLLY Motherboard
Installing new Window xp and other devices didnt works
take the side of the computer off and look for the model number on your motherboard. you need to know if your using a network card or if its onboard Lan. if everything you need is onboard all you need to do is search your motherboard number on the internet and download the drivers. you need can select what you need, sound, lan etc. your goning to have to use a friends pc so you can download these files. when your Lan is installed go to the microsoft webpage and get the latest updates, that will solve the usb in your device manager
Sep 08, 2008 | Computers & Internet
Drivers
The onboard Network card is based on the nVidia nForce 4 chipset that is also the standard Motherboard Chipset. This can be downloaded from the Asus Website.
Are you having any difficulty with the Onboard LAN or is this just an issue of getting the driver for the LAN card installation?
Apr 22, 2008 | ASUS A8N-E Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Linksys Wireless-G WUSB54G 802.11g/b Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
