Question about Kenmore 24032\24036 Top Load Washer
My machine stopped in middle of rinse cycle - tub full of water
I've unplugged, flipped breaker, waited an hour. Nothing. I had two rugs in a supersize load. I've done this before with no problem. It may have got out of balance, but I took the rugs out and still nothing. My washer is a super simple one, no bells or whistles. Help.
  • 63 Answers
If there is no sound its sounds like your lid switch is broken
Posted on Jan 20, 2009
Rinse Light Flashing and Cycle stops. What could it be ?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you may have selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
Jun 22, 2015 | Washing Machines
My Telmann xqb45-268gps washing machine fills with water, washes, but wont rinse. Help!
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
TIMER
May 17, 2015 | Washing Machines
Washing machine is not rinsing properly
TIMER
Feb 21, 2015 | Beko Washing Machines
My washer has water in tub after the washing cycle
Hello Romy, approximately about how much water is left after the cycle? In this case, I would recommend reprogramming the washer by either unplugging it or flipping the household circuit breaker. It is important to wait ten minutes and then turn on the unit. If the issue persists, then more than likely the washer could possibly have a faulty fill water valve that is allowing water back in or not draining properly.
Jul 26, 2013 | Frigidaire Affinity ATF7000E Front Load...
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
Machine didn't empty water after rinse cycle. Now
Check for power at socket using a lamp. If nothing, check the breaker for that circuit in the house electrical panel--push OFF, then ON. If now get light, try the washer again. If you get a loud hum from the machine, it may be a locked motor. Pull the plug again and check the motor. The tub can be drained by lowering the end of the drain hose below the interior water level.
Aug 01, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
