Question about Arris DCT6200 DTV Receiver
Motorola DCT 6200/1000 seems to only have one audio output?
I have a Series 2 DT TiVo hooked up to my DCT 6200/1000 with RCA cables. I also have the cable box hooked directly to my T.V. through component cables. The Component input on my T.V is showing both audio and video, but the cable input ( with the TIVo) does not have sound coming from my cable box. Can anyone confirm that the DCT 6200/1000 only has one audio output, and, if so, is there any possible setting to change or firmware update to change that?
  • 1 more comment
  • misty_ricker Jan 17, 2009
    It has two sets of component ports. red, white, red, blue, green.
    Thanks, I will explore all of those options. Can you also verify whether this cable box is only able to output one audio source?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does your unit have a yellow, red, and white input jacks?
    It should have that but the order on it is a little different.
  • 2,794 Answers
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Posted on Jan 17, 2009
Tivo turns off TV
For some reason your Tivo is tripping the internal breaker of your TV. Check the cables and see that they are not damaged and are connected properly (all the cables that hook up to the Tivo). If you have a spare set of cables, try them to see if the TV still turns off.
Jan 01, 2008 | Tivo Series 2 80-Hours Video Recorder
Tip
Play Tivo HD Videos on Motorola Droid X,TS Tivo to Droid X How to convert and...
How to convert and play TiVo shows on Motorola Droid X? To solve this problem, you need to transfer TiVo, TiVo HD shows to your PC and then convert them to Motorola Droid X MP4 format with Aunsoft Droid X Video Converter. With the recommended software, you can convert TiVo, TiVo HD, TS TiVo shows to Droid X mp4 by yourself fast and easily!
How to convert TiVo to Motorola Droid X MP4?
This guide includes 3 parts:
Parts 1: Transfer TiVo shows from TiVo DVR to PC
Parts 2: Convert TiVo to Motorola Droid X MP4.
Parts 3: Transfer converted TiVo shows to Droid X.
To transfer TiVo shows to PC, you need to download TiVo Desktop Software. When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your PC.
After you transfer TiVo files to your PC, you can convert them to Droid X mp4 format. First of all, download TiVo to Droid X Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo to Droid X Converter
Enter Media Access Key for your TiVo files from “Option” button and then load TiVo files to the TiVo to Droid X Converter.
Step 2: Edit TiVo files
Editing functions are available by clicking “Editor” button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check “Apply to all” to apply the present settings to all the TiVo files.
Step 3: Choose Motorola Droid X MP4 output format
After you finished editing, you then choose output format from “Format” drop-down list and specify the format Motorola Droid X H.264 Video (*.mp4) (recommended) under Android profile among the options.
Tip: The default resolution of output format H.264 MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) to 800*480 or 854*480, or you can custom the resolution if you wish to.
Step 4: Convert TiVo shows to Droid X MP4
Click “Convert” button to start converting TiVo to Droid X MP4. Check “Merge into one file” to join all TiVo files to one output Droid X mp4 file before start conversion.
After converting your TiVo shows to Droid X, you will get mp4 file(s) in destination folder. Then you can transfer your videos to Droid X for playing, if you have any problem on transferring files. Please read: Transfer or Copy Movies and Musics to Motorola Droid X.
Now you are free to enjoy your TiVo recordings on Droid X wherever you go.
on Aug 04, 2010 | Cell Phones
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Dvr not connecting to tivo
Try 255.255.255.0 for a subnet mask. That should be the one by default. Usually the network setup on your Tivo should be automatic when it looks for the router. Is the wireless turned on the router?
Aug 28, 2008 | Televison & Video
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Tivo Programing
You either don't have it hooked up right w/ the source video cables connected or if you've changed setups from one tv to another (different cable box or input) you need to go through guided setup again, but first check your cables, ensure they are going to the inputs (rca or coax) and not going to the outputs.
Dec 03, 2007 | Tivo Series 2 80-Hours Video Recorder
Series 2 tivo
You shouldn't unplug the ribbon cable and power on the unit, ever!
Make sure the ribbon cable is 100% in the motherboard, and the front ribbon cable as well, also ensure they aren't damaged. If you can't even get the startup screen, or any type of video output, then your motherboard is most likely shot and I'd see what tivo can do for you.
Nov 25, 2007 | Tivo Series2 TCD649080 Video Recorder
How to connect to digital cable box and TIVO
Click here and start at page 24 to see a diagram on how it should be hooked up.
Sep 23, 2007 | LG 42PC3D 42 in. Plasma Television
Arris DCT6200 DTV Receiver Logo
1,133 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
