Question about Kenmore 24032\24036 Top Load Washer
The washer (Kenmore Top Loader Model# 24642300)
Was filled with clothes and water and was working but stopped then there was a humming noise like the starting button was trying to operate but nothing.
  • bluesmanxb40 Jan 17, 2009
    The lid switch is working. Still has a humming noise and dosen't operate.
    Novelist:
  • 101 Answers
It most likely is the coupler. It is located between the motor and the transmission. It is an easy repair and only costs around 20 dollars. To change it out simply unplug the washer and tip it back so you can work under it. The first thing you will see is the pump. Take off the two clamps with a flat head screw driver and move it to the side. Do not take off the hoses unless you want water everywhere. Next you will see the motor. The motor is held up by two clamps. The clamps have 2 screws in each one. Remove the screws and with your flat head pop off the clamps. Make sure you hold the motor cause when you take off that first clamp the motor will drop. The motor coupling will come off with it. Put your new one on, (it only goes on one way) and put everything back together again. You will be up and running good as new in no time again. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad to help.
Posted on Jan 22, 2009
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
