Question about Maytag Dryers
Gas dryer does not seem to heat up the air
Our dryer seems to use only cold air, and it takes hours to dry anything.
any suggestions?
  • DiamondDave7 Apr 12, 2009
    Burner never comes on and the dryer runs forever. Have cleaned out inside cabinet, burner, lint track and fan. What next??? Thanks
Thank you. It looks like *sometimes* it works just fine.
The next batch - after I posted the problem - was dried OK.
Maybe it was indeed clogging.
No gas smell, by the way.
Posted on Jan 18, 2009
  • 979 Answers
Do the gas burners come on at all and is the pilot light on as well. The orifices could be clogged or dirty or not combusting right. Do you smell gas any when you turn it on? Let me know so I can maybe help further.
Posted on Jan 17, 2009
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Isn't heating up. takes forever to dry,
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Apr 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Takes hours to dry small load
You have a build of of lint inside the unitm which is cutting air flow. Look outside at your exhaust. clean it and check how much air flows out.
Aug 30, 2009 | Whirlpool GEW9250 Electric Dryer
No heat - long time to dry clothes.
Hi, Is this an electric dryer? The model# shows that is it. If it is gas, you need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $27.95. Our # is 1 866 798-4375 Make sure and check the venting to the ouside and make sre that it is clean and has no kinks.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I have a LG front load dryer only just 2years old and it takes several cycles to dry clothes. It seems to heat but not to its potential on high settings. It took 4 hours to dry a load of towls. I had it on...
Hello Kimwbarrym,
Maybe I can give you a few ideas on some things to check. As a general rule of thumb, to get maximum support here at Fixya, you should always include the brand and model of your appliance.. That helps us to tailor responses to your specific problem.. Anyway, regardless of dryer model, they all pretty much operate in the same basic manner and that is.. there is a heat source ( electric dryers use an heating element similar to an electric stove) A gas dryer is essentially the same but uses gas with an igniter to create a flame on a burner..) Outcome is the same.. Heat
Once heat is established, you need to move the clothes and the air thru the dryer compartment to optimize the drying efficiency. Both gas and electric models use a blower to move that heated air thru the compartment and out thru your vent system. If anything restricts air movement ( lint, blockage or any restriction in the blower or filter) your drying efficiency drops way down and dry times go way up. So. now you have the basics on how a drywer works.. Having said that... you need to check the basics first.. Make certain that you dryer exhaust system has NO restrictions to air flow.. you may have to detach vent line and check it for lint or anything in there.. If you have an electric dryer.. you can turn it on for a minute or two with the vent linbe disconnected to see if you are getting robust air movement.. If you aren't , then your problem is internal to the dryer, If you are.. you may have an exhaust duct restriction. Although not recommended, you can do the same for a gas dryer in a well ventilated area just to check the flow intensity.. But.. only for a short time since the gas burn byproduct is unhealthy for you to breath. I forgot to mention that the drum inside the dryuer should be moving the clothes during all this.. that acellerates the dry cycle too. Lastly, you need to make sure you are getting heat.. You can start a dry cycle with the dryer empty to see how warm it gets.. It should get fairly warm. Not sure I helped you but you now have a few things you can try. If you continue to have problems with this, feel free to contact me via this forum but please include the model number of your LG appliance..
Regards,
Rick
Dec 02, 2008 | LG Dryers
Dryers Logo
76 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
