Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
    New Friend:
  • 18 Answers
To defrost the coils quicker:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Posted on Dec 04, 2013
  • 15 Answers
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Posted on Jan 17, 2009
Freezer not cold enough to freeze ice cream and bread.. I have setting at coldest. What else should I check?
First check the manufacturers website for troubleshooting. When refrigerator or freezer not cold enough, typically the problem is the freon is low or a more expensive repair is your compressor might be on it's way out! Sliding Pull Out Shelves Denver Colorado
Mar 09, 2017 | Refrigerators
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Simple Vanilla Ice Cream from recipe booklet is still staying liquidy. Have done everything as instructed. Ingredients are well chilled and ice cream bucket has been in the freezer for two days. Have had...
Your freezer is not cold enough. I had a heck of a time with this machine the first few attempts, when I was in storing it in my main freezer (less cold than the one in my garage). Then i froze the bowl in my garage freezer - it is set to below 32 degrees Farenheit and is designed for long-term storage (gives anything I put in it major freezer burn). When the freezer is set to a low enough temperature, you will find that even 14 minutes is plenty of time to acheive the desired ice cream consistency in the ICE-45 (without having to pre-chill the ingredients).
Other things to check:
Make sure you are using heavy whipping cream and not half-and-half or other substitute.
Make sure that you wait until you are ready to pour the ingredients into the bowl BEFORE taking the bowl out of the freezer.
Aug 18, 2009 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
May 20, 2009 | Refrigerators
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
Tank won't freeze
The keys are to make sure the freezer is cold enough, and to make sure the bowl is level when it is sitting in the freezer. 24 hours is usually required, despite what manual says.
If all else fails, the freezer bowls are replaceable - you can order them from Cuisinart - if you are in-warranty, they may even be able to give it to you for free.
-tha Mp3 Doctor
Jul 08, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
630 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
