Question about RCA F36650 36" TV
Who do u replace a flyback transformer yourself?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It depends on skills and experience of person to replace flyback transformer.
    Problem Solver:
If you have never worked on anything eletrical or electronic before, it may be a bad idea, there is very hi voltage in side the tv even if it has been unpluged for days. Unless you aready know about the dangers as well as how to safly dischare it i would just get a new tv. A new tv is much cheaper then getting eltrocuted. As far as actully putting one in, it isnt to bad, u need a good soldering gun, soldier, and a desoldering tool. Its definaty not plug and play there is work to get it solderd in there at least 20 solderng connections. If you have never soldered then its not worth the risk. if you have the eltronics safty know how, then its maybe a 35 minute job
Posted on Jan 22, 2009
Noisy flyback transformer tcl CRT TV model 14F1
They often begin buzzing when the oil inside them gets old or evaporates from a cracked housing. It needs replacing however be very careful. Flyback have 50000 to 100000 volts in them even when the tv is off. There is a safety discharge procedure however if you are not familiar with replacing a flyback do not attempt it yourself. FLYBACK TRANSFORMERS CAN SEVERLY INJURE OR KILL YOU.
Jul 17, 2016 | Televison & Video
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
Replaced Flyback Transformer and Horizontal Output Transistor
how miuch was the repair can you do it yourself
Aug 13, 2008 | RCA F36650 36" TV
Phillips 60pp9202 high voltage transformer
You can get the HV Transformer at the following link for 132.00 which includes free shipping and free step by step instructions by online instant messaging so you can easily replace the part yourself. Very easy repair. The HV generator is listed under the flyback section yours is Phillips 32942 Flyback ( HV Transformer)
Heres the link.
http://servicemanuals.vstore.ca/
Aug 01, 2008 | Philips 60PP9202 60" Rear Projection...
Tv turns on then a few seconds later turns off
There is a bad flybaack transformer inside the TV. It shuold be repaired by a TV repairman.
Jul 21, 2008 | Philips Magnavox 20MS233S 20" TV
RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
May 29, 2008 | RCA F32650 32" TV
Flyback transformer bad
Still Caps can hold charge for longer than that. Do you know for sure this is the problem. If not then, you maybe shooting yourself in the foot sort of speak. You would need a desoldering tool, iron or gun. Have you check the cost, because most flyback for projection cost maybe over 100. So it maybe easier and safer to call PTS 18008447871 and give them the tv model and what the problem is.
Sep 13, 2007 | Philips 51PW9303 51" Rear Projection...
Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Sep 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA F36650 36" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
