Wire hook up for Channel Master 9510A
We removed the wires to this unit and want to hook it back on. What color goes to which number?
  • 2 more comments
  • phdaddy Mar 21, 2009
    I took off the wires from the controller and then found the manual was missing. The model 9510
  • kate Jul 21, 2013
    We have same problem, then we looked and it was written B R W, but unit was upside down (the writing and numbers) So we are assuming Black red white with cord on top of unit.
  • kate Jul 21, 2013
    I had same problem. Black, Red, White is written on the back of mine, upside down writing on the unit, in other words, the cord is sticking on top, and the numbers read 1 2 3 but they are upside down.
  • kate Jul 21, 2013
    well we hooked it up, it doesnt stop where we put it and the antenna doesnt move! the installer never did deliver our remote after we got new stuff from a storm. $1000 for..?
Wireing for channel master 9510
Posted on Mar 23, 2009
I re-worded my google search!
Thanks anyway!
Posted on Jan 18, 2009
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Wires got pulled out by mistake don't know what wire goes where the wire is old and discolored help!!!!
Is your wiring where it's hooked into the furnace still identifable as to color. If so one way to tell whats what is to remove wires from furnace one at a time and disconnect all wires from base of thermostat. Use a ohm meter and one very long test wire. Hook to known wire on one end and use test wire to check wires on t-stat end. When you read closed circuit reattach wire to furnace and lable t-stat end as to color. Connections on base of thermostat should be marked with R,W,G,and y. Check each wire one at a time and when you know what color each wire is hook t-stat base back up,put cover back on and check out. A much eaiser way if you can identify wire color and existing wire is accessible in basement or whever your furnace is . Discconect wires from furnace and see if you can pull wire back up to thermostat. If you're lucky they won't be stapeled inside wall. If you can move wire easily buy approximate length of new wire at hardware store. Most of them will sell wire by the foot. Strip about 3/4 inch of insulation from each wire and twist all wires from old to new and wrap all of it with electrical tape. Carefully pull new wire to t-stat and connect there and to furnace. Good luck. I hope this helps. Thanks
Nov 17, 2010 | Honeywell YCT87N1006 Heater
Buddy gave me the unit. No wiring instructions, only the leads. Spearkers n ant self-explanatory. Others?
well to give you a quick run down of wire colors:
red: hook to an (fused) ignition wire. pos. (+)
yellow: Goes to a fused constant wire (battery works)
Black: is a ground (-) hook that to the chassis
blue: Amp turn on output (+)... that goes to an amp
the color pairs i.e. white, green, purple, gray are for the speakers, the (-) is the the one with the black stripe... what else would you like to know?
Apr 29, 2010 | Sony CDX-M630 CD Player
We need to reattach the wires to the Channel Master 9510A unit but are unsure which color goes to which post. We have a red, white and black on the tip wires. Can you help?
Can't wait around for your response, so I kept looking on the web until I found a users manual that showed how to connect the wirew.
Thanks anyway.
Sep 12, 2009 | Channel Master Televison & Video
Need help with wiring thermostat
first do you have a heat pump unit or standard a/c? standard a/c connections at the thermostat go like this red wire to rh-rc which is the 24v power and you don't have to remove the jumper.white goes to w which is the heating wire yellow goes to y which is the cooling wire green goes to g which is the fan wire and blue goes to c which is the common wire. so if your stat has rc- rh ywgc you should be set if the wires on the furnace correspond with the same alpha may be used if u have a heat pump unit otherwise it may just be a spare you cap off and leave behind the subplate.
May 31, 2009 | Honeywell Heating & Cooling
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
Trying to rewire cartridge
Red - Right Channel +
Green - Right Channel -
White - Left Channel +
Blue - Left Channel -
John w
Jan 30, 2008 | Audio Players & Recorders
Mine is actually a q4000 4 channel amp
First of all, you MUST HOOK UP YOUR GROUND WIRE FIRST. You may have damaged it if you hooked your power and trigger wire first and then the ground wire. Unhook EVERYTHING except the hot wire, ground wire and trigger wire. If you still can't get the unit to come on then it is time for a trip to the repair shop. Good luck.
Feb 01, 2007 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
Televison & Video Logo
2,503 people viewed this question
Top Televison & Video Experts
