Question about Philips GoGear SA3125/37 MP3 Player
Mp3 won't stay on
Turn on and (philips) will light up on the display the go off. then nothing.
plug into computer and (Ok to disconnect) comes on and only shuts off when battery is removed help
  • Anonymous Jan 26, 2009
    my just goes to a blank screen and then turns off.
  • Anonymous Feb 15, 2009
    NOT WORKING
  • 8,596 Answers
Make sure that the hold/lock switch isn't engaged, and make sure it has been plugged into the computer for 3-4 hours to fully charge.
If it still won't work, run a Repair in the Philips Device Manager.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
Unit won't turn on with new batteries
check the battery terminal if their is a contact, if ok it could be a problem in the power circuit.
Sep 20, 2012 | RCA Th1814 4 Gb Mp3 Player With Flip-out...
Still not working...
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Cant bring up anything when connected to computer
You have to use Windows Media Player to transfer files to the device. Here is a link to the manual:
http://www.p4c.philips.com/files/h/hdd075_17/hdd075_17_dfu_aen.pdf
-Tha Mp3 Doctor
Jan 27, 2009 | Philips GoGear HDD075/17 MP3 Player
WHEN I PLUG IN MY SA3245 NOTHING SHOWS UP ON THE COMPUTER MONITOR
OK to Disconnect just means ur battery is full and no files are in transfer to the device. After changing battery, the device will update fora minute, if after a decent ammount of time goes by and nuthing happens, use a pin and hold down the reset button, forcing the device to power down, turn it back on and try to let it update again
Dec 29, 2008 | Philips GoGear SA3245/37 Digital Media...
Mp3 won't stay on
Reset the player first. If that fails:
-Tha Mp3 Doctor
Dec 22, 2008 | Philips GoGear SA3125/37 MP3 Player
Philips SA5125/37
First you should hold down the go back button on your mp3 while still holding this button, plug it into the usb port. While still holding the button open up the philip device manager, this should instantly start to repair your device. While it is repairing you can let go of the go back button
Oct 24, 2008 | Philips SA5125/37 MP3 Player
Go gear 4 gb turns on thean says
Sounds like normal behavior to me. It only gives you menu, playback when it is DISCONNECTED fro mthe computer.
Oct 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Power wont stay on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
The run the Repair and the Update in Philips Device Manager.
Jul 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
