Question about Logitech Z-4 Computer Speakers
NO SOUND FROM MY RIGHT SPEAKER Z4
REALTEK SHOW AS THE AUDIO MANAGER. I SEE NOTHING FOR THE LOGITECH Z4 SPEAKERS. I RAN TEST AND IT VERIFIES THAT THERE IS NO SOUND.
I THINK I NEED THE CONNECTION INSTRUCTIONS SINCE I CAN NOT FIND MINE.
PLEASE HELP.
THANKS.
  • John D John Jan 24, 2009
    my right speaker make a voice, but its only a bit, and after i change the cable to the other speaker same problem happens. can anybodyu helllpp
  • 52 Answers
Open
Startmenu->control panel->sound and audio devices
Do you see a window which says "no audio devices installed" ?
  • If yes then its a driver problem, you need to install audio driver for your PC.
  • if no then, click on "Speaker volume button" below, then click "restore defaults" button.
This should fix the problem.
Otherwise I would suggest some more.
Posted on Mar 17, 2009
How do I fix my realtek speakers? They play sounds and music but while doing so the sound icon in the taskbar is showing movement from bottom to top with sound increasing as it goes upwards?
Open Device manager and right click on "Realtek HD Audio"
Select 'enable'
Right click on the speaker icon in the taskbar and select 'Playback devices' ensure that Realtek is checked as the default speaker device
Right click alongside the speaker icon and make sure they are not disabled
Use the 'Test' facility to check the audio
You may have to update the driver as well
Jun 25, 2015 | Realtek Semiconductor Realtek High...
Need the logitech Z4 user manual
connect it to the back of your computer, many monitors dont have 1/8 pin connections for audio out
Apr 20, 2013 | Logitech Z4 Speakers
Hi, i just recently upgraded my OS from winXP to win7. However, after installing win7 i couldn't get any sound from my pc. Device manager says that the driver is working fine. I checked the settings of...
go to control panel then hardware and sound then go to manage my sound devices under that will find playback under that you will have to click on speakers(single click) and and then the configure option gets activated then you have the option to check the speaker functionality and also you can go to sound tab select a sound and click on test to check it
Oct 27, 2010 | Realtek Semiconductor Realtek High...
Crackling sound
The crackling could be due to a faulty wire or jack connection. If you have any other sound device (e.g. headphones), try connecting that one instead of the Z4 and see whether the crackling disappears (in which case it's the Z4) or not (in which case it's the jack or the computer). Could arguably be an EM or electrical interference, but you'd need a laptop running on batteries to check the second, and trying orienting differently the speakers to try checking the first.
The music slowing down means something's wrong in the computer: the Z4 are purely passive, they can't do anything to the music tempo. Try running an antivirus check or try Task Manager (or Process Explorer) and see whether anything's eating more CPU than it should.
Mar 28, 2010 | Logitech Z4 Speakers
Logitech X-540 limited sound
why dont you have them all hooked up? I have the same speakers but I the model that only has 2 speakers. Try pluging your audio cable in the front where you would plug head phones in. Assuming that this is a desktop.
Jul 24, 2009 | Logitech X-540 Computer Speakers
Asus M2V Audio problem
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
I AM GETTING NO SOUND FROM MY LEFT SPEAKER.
Connect the speaker pin to the light green speaker point(most probably the middle one) on the back of your PC.
Open
Jan 17, 2009 | Logitech Z-4 Computer Speakers
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
How do I connect my Logitech X-540 speaker to my laptop an
I just opened my Realtek HD Audio settings and clicked on 5.1 sound.. then assigned the different ports.
Make sure you have the latest audio driver update for your soundcard, and go through the software options, it'll be there somewhere..
If you think you might have a RealTek soundcard, you can find newest Realtek HD audio drivers here:
http://rapidshare.com/files/173930788/Vista_R211.zip
Has XP support too. Install and reboot, then the 'red' realtek volume icon should appear in the bottom right hand corner of the screen.
You'll find the settings manager in there.
Good Luck
Chris (ziraffa)
Dec 23, 2008 | Logitech X-540 Computer Speakers
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
Logitech Z-4 Computer Speakers Logo
501 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
