Question about Batteries.com 8148 Nickel Cadmium 2-Way Radio Battery
Defective Ni-Cad Battery
I have an 18 volt Craftsman Nickel Cadium battery that will not take a charge. The charger has 3 lights. I heard they can be repaired. How?
  • 21 Answers
Try Re-Conditioning the battery first. Full procedure at: ysuusy.com/easybatteryfix.html
"Cordless Power Tool Batteries and other batteries that contain Nickel Cadmium (NiCd) Cells can be Re-Conditioned to perform as well as new or even better than new. Proper maintenance after the procedure will insure years of usable life.
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and become smaller. These smaller crystals have a greater surface area and therefore contain a greater capacitance for energy. "
Posted on Mar 10, 2009
  • Batteries.com Master
  • 1,640 Answers
There are several companies who repair or can replace the NiCD batteries used on tools. Try googling the name of the product etc. (ie. "craftsman drill battery replacement")
Posted on Jan 18, 2009
My 4 year old Daughter left my craftsman light 19.2 on all night. When i went to charge it, the charger said the battery was defective.
I didn't want to believe it so I tried a trick. After applying the trick, I tried to charge the battery and this time the charging light came on.
Hurray the trick worked. This trick should work for any battery. Please visit my web page to see the trick... my TIP is free but I like to track the page counts to see if people have this same problem I do.
So before you open up your battery and replace the cells try my TIP first.
http://www.geocities.com/fongbar/tech/dischargednicad.html
Posted on Mar 22, 2009
Icom bc-179 do not charge the battery
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
Nov 17, 2013 | ICOM Informatique Radio Communications
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
My 18 volt worx battery will not hold a charge
A lot of ni-cad packs have one or two bad cells. to find the bad one(s); unscrew the cover on the battery pack and use a voltmeter set on dc volt 2v full scale and test the cells one at a time. they should each have at least 1.25 volts. The bad cells can be removed and replaced with good cells from other discarded packs. If they're not too old many ni-cad cells will still work. You can also revive some cells by unplugging the vent hole in the top of the cell so it can breathe (seriously). Also, I have zapped single cells by momentarily connecting them one by one (even in the pack) to a car battery. plus to plus,minus to minus. But only for about a half second. Also, heating ni-cads will kill them.
Dec 22, 2012 | Worx Ni-Cad Replacement Battery, 18 Volt
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
Cordless drill - model KC9682C - probably 8 years old. Stopped working shortly after a battery re-charge. I'm guessing it's the battery. It charges for a few minutes then the red light goes off. Could it...
If light is on charger the charge is fine. You could verify using voltmeter it should put out = to what it says on the back of charger 12-18 volts or so.
Most likely battery is shot after 8 years they just dont' hold a charge anymore and they often will only charge for a few minutes when the chip in the computer tells the charger to shut off due to defective battery.
compare prices of new drills and new batterys sometimes new drill is not much more. Try ebay and harbor freight for ultra low priced batteries.
Mar 03, 2011 | Black & Decker Drills
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Batteries will not charge
Ni-cad will go bad if they sit for a long time
before charged, now Ni-mi you can charge it
at any time,so next ask or look for NI-MI
they will know what you are talking about.
Hope this helps.
Sep 09, 2009 | Porter Cable-Cable PCL180DK-2 18-Volt...
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
We have a Firestorm drill and have had conflicting advice on charging the batteries. which is correct flatten the battery right down or charge as soon as it loses power. ?? thankyou Colin.
There are different types of battery, the old ni-cad (nickel cadium) batts lasted longer if you let them run right down before recharging them as they had a 'memory' which meant if you charged them from half life they wouldn't charge as much after a while. The new Ni-mh (nickel metal hydrate) and li-ion (lithium ion) batterys don't suffer from this problem so you can recharge them whenever you fancy. The li-on batts don't tend to run compleetely out of charge as when tehy have lost a certain amount of power they just stop anyway. If your batt has lost some life it is possible to get it re-formatted' in some cases by having it put on a battery discharge tester. This is a bit of kit that fully discharges a battery from full in a short space of time and measures it's capacity by timing it. Because it completely discharges and recharges teh batt acouple of times quickly it can someetimes reinvigourate the batt.
Nov 05, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Batteries.com 8148 Nickel Cadmium 2-Way Radio Battery Logo
644 people viewed this question
Top Batteries.com Radio Communications Experts
Dan Kostella
Level 1 Expert
eradiostore
eradiostore
Iron
Iron
Are you a Batteries.com Radio Communication Expert? Answer questions, earn points and help others
